Hi Terry,
Thank you for the pointers. All our settings are correct as everything worked fine before the SIP provided migrated their SIP Servers.
Here is deb ccsip mess , first call coming in fine:
VG01#
000147: Mar 1 11:33:43.122: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:61395XXXXXX@10.18.0.2:5060 SIP/2.0
Record-Route: 103.78.194.111>
Record-Route: 103.78.194.111:5060>
Via: SIP/2.0/UDP 103.78.194.111:5060;branch=z9hG4bKa5ed.64cedfb5d0b95f3486d3a11d1098e170.0;i=5be1
Max-Forwards: 69
To: 61395xxxxxx>
Call-ID: 49f23f34649b64eb51c15c440f27d608@103.78.194.111:5050
Contact:
CSeq: 102 INVITE
User-Agent: Binary Elements CVP2
Date: Sun, 01 Mar 2020 11:33:43 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH
Supported: replaces, timer
X-voipnow-did: 61395XXXXXX
X-voipnow-extension: 0586*004
X-voipnow-pbx: 86ec00cec6
X-voipnow-infrastructureid: 472c5540
X-voipnow-recording: disabled
Content-Type: application/sdp
Content-Length: 357
v=0
o=root 1276218876 1276218876 IN IP4 103.78.194.111
s=VoipNow
c=IN IP4 103.78.194.111
t=0 0
a=msid-semantic: WMS
m=audio 10550 RTP/AVP 8 0 3 101
a=rtcp:10551 IN IP4 103.78.194.111
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:3 GSM/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
000148: Mar 1 11:33:43.134: //463/56F77C4684F1/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Dan Constantinescu
T1300 144 984
E Dan.Constantinescu@vitg.com.auW vitg.com.au
Sydney | Melbourne | Brisbane | Wollongong | Newcastle
PRIVATE AND CONFIDENTIAL This email and any attached files or documents are confidential, and intended solely for the use of the intended addressee. If you are not the intended recipient, any use, disclosure, dissemination, printing or copying of this email is unauthorised and prohibited. If you have received this by mistake, please notify the sender immediately and delete the email and attachments from your system. To the extent permitted by law, Virtual IT Group and its associates will not be liable for any loss or damage arising in any way from this transmission.
To: 61395xxxxxx>
Date: Sun, 01 Mar 2020 22:33:43 GMT
CSeq: 102 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.4.3.M10
Content-Length: 0
000149: Mar 1 11:33:43.134: //464/56F77C4684F1/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:7711@10.18.0.10:5060 SIP/2.0
Via: SIP/2.0/UDP 10.18.0.2:5060;branch=z9hG4bK1C0687
To: 7711>
Call-ID: 56F950BD-5AE711EA-84F79F32-572993B0@getartisan.com.au
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 1459059782-1525092842-2230427442-1462342576
User-Agent: Cisco-SIPGateway/IOS-15.4.3.M10
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1583062423
Contact:
Expires: 180
Max-Forwards: 68
Content-Disposition: session;handling=required
Content-Length: 267
v=0
o=CiscoSystemsSIP-GW-UserAgent 6986 3930 IN IP4 10.18.0.2
s=SIP Call
t=0 0
m=audio 16504 RTP/AVP 0 100 101
c=IN IP4 10.18.0.2
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
a=fmtp:101 0-15
a=ptime:20
000150: Mar 1 11:33:43.138: //464/56F77C4684F1/SIP/Msg/ccsipDisplayMsg:
Received:
VG01#SIP/2.0 100 Trying
To: 7711>
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
000151: Mar 1 11:33:43.450: //464/56F77C4684F1/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: 7711>;tag=639692~12019a10-0c44-4788-9668-800846fb84a7-23940895
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Server: Cisco-CUCM11.5
Call-Info: ;x-cisco-video-traffic-class=MIXED
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Session-ID: 69cdb6af6ab18451c9af31d1ab639693;remote=9488bf6d3fbf29a77d34ed8aab639692
P-Preferred-Identity: 2000>
Remote-Party-ID: 2000>;party=called;screen=no;privacy=off
Contact: 7711>
Content-Length: 0
000152: Mar 1 11:33:43.454: //463/56F77C4684F1/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: 61395xxxxxx>;tag=23CCA1C-11D8
CSeq: 102 INVITE
Contact: 61395xxxxxx>
Record-Route: 103.78.194.111>,103.78.194.111:5060>
Content-Length: 0
000153: Mar 1 11:33:43.566: //464/56F77C4684F1/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Allow-Events: presence, kpml
Supported: replaces
Session-Expires: 1800;refresher=uas
Require: timer
Contact: 7711>
Content-Length: 232
v=0
o=CiscoSystemsCCM-SIP 639692 1 IN IP4 10.18.0.10
s=SIP Call
c=IN IP4 10.18.0.2
b=TIAS:64000
b=AS:64
t=0 0
m=audio 16506 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
000154: Mar 1 11:33:43.570: //464/56F77C4684F1/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:7711@10.18.0.10:5060 SIP/2.0
Via: SIP/2.0/UDP 10.18.0.2:5060;branch=z9hG4bK1C1776
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
000155: Mar 1 11:33:43.574: //463/56F77C4684F1/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 218
v=0
o=CiscoSystemsSIP-GW-UserAgent 6189 9739 IN IP4 10.18.0.2
s=SIP Call
t=0 0
m=audio 16502 RTP/AVP 0 101
c=IN IP4 10.18.0.2
a=fmtp:101 0-16
a=ptime:20
000156: Mar 1 11:33:43.590: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:61395XXXXXX@10.18.0.2:5060 SIP/2.0
Via: SIP/2.0/UDP 103.78.194.111:5060;branch=z9hG4bKa5ed.7b6656582526e273168f8cb240b170a9.0;i=5be1
Max-Forwards: 69
Contact:
CSeq: 102 ACK
Content-Length: 0
000157: Mar 1 11:33:44.206: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:103.35.128.10:5060 SIP/2.0
Via: SIP/2.0/UDP 103.78.194.111;branch=z9hG4bK4e5a.20357792000000000000000000000000.0
To: 103.35.128.10:5060>
CSeq: 10 OPTIONS
Call-ID: 7f65034c01c8079e-1864@103.78.194.111
Max-Forwards: 70
Content-Length: 0
000158: Mar 1 11:33:44.210: //185404173/0B0D0B0D0B0D/SIP/Msg/ccsipDisplayMsg:
Sent:
VG01#SIP/2.0 400 Bad Request - 'Invalid IP Address'
To: 103.35.128.10:5060>;tag=23CCD14-BD6
Date: Sun, 01 Mar 2020 22:33:44 GMT
CSeq: 10 OPTIONS
Content-Length: 0
VG01#
000159: Mar 1 11:33:54.322: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 103.78.194.111:5060;branch=z9hG4bKaa86.96abd60b757f3e94d344168a0c044d68.0;i=5be1
Max-Forwards: 69
To: 61395xxxxxx>
Call-ID: 4f4ecbae516c85d82d17d72761db298f@103.78.194.111:5050
Contact: 61418xxxxxx>
CSeq: 102 INVITE
Date: Sun, 01 Mar 2020 11:33:54 GMT
Content-Length: 357
v=0
o=root 1788883593 1788883593 IN IP4 103.78.194.111
s=VoipNow
t=0 0
m=audio 11056 RTP/AVP 8 0 3 101
a=rtcp:11057 IN IP4 103.78.194.111
a=rtpmap:3 GSM/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
000160: Mar 1 11:33:54.334: //468/5DA47C8484FC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: 61395xxxxxx>
Date: Sun, 01 Mar 2020 22:33:54 GMT
CSeq: 102 INVITE
Content-Length: 0
000161: Mar 1 11:33:54.334: //469/5DA47C8484FC/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.18.0.2:5060;branch=z9hG4bK1C214E7
To: 7711>
Call-ID: 5DA65195-5AE711EA-85029F32-572993B0@getartisan.com.au
Min-SE: 1800
Cisco-Guid: 1571060868-1525092842-2231148338-1462342576
CSeq: 101 INVITE
Timestamp: 1583062434
Expires: 180
Max-Forwards: 68
Content-Length: 267
v=0
o=CiscoSystemsSIP-GW-UserAgent 8262 4549 IN IP4 10.18.0.2
s=SIP Call
t=0 0
m=audio 16512 RTP/AVP 0 100 101
c=IN IP4 10.18.0.2
a=fmtp:100 192-194
a=fmtp:101 0-15
a=ptime:20
000162: Mar 1 11:33:54.338: //469/5DA47C8484FC/SIP/Msg/ccsipDisplayMsg:
Received:
To: 7711>
CSeq: 101 INVITE
Content-Length: 0
000163: Mar 1 11:33:54.690: //469/5DA47C8484FC/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: 7711>;tag=639698~12019a10-0c44-4788-9668-800846fb84a7-23940903
CSeq: 101 INVITE
Session-ID: 69cdb6af6ab18451c9af31d1ab639699;remote=9488bf6d3fbf29a77d34ed8aab639698
Contact: 7711>
Content-Length: 0
000164: Mar 1 11:33:54.694: //468/5DA47C8484FC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: 61395xxxxxx>;tag=23CF608-235A
CSeq: 102 INVITE
Content-Length: 0
000165: Mar 1 11:33:54.782: //469/5DA47C8484FC/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 503 Service Unavailable
CSeq: 101 INVITE
Reason: Q.850;cause=47
Content-Length: 0
000166: Mar 1 11:33:54.782: //469/5DA47C8484FC/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
000167: Mar 1 11:33:54.782: //468/5DA47C8484FC/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 102 INVITE
Reason: Q.850;cause=38
Content-Length: 0
000168: Mar 1 11:33:54.798: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
VG01#ACK sip:61395XXXXXX@10.18.0.2:5060 SIP/2.0
Max-Forwards: 69
CSeq: 102 ACK
Content-Length: 0
VG01#
000169: Mar 1 11:34:04.438: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:61395XXXXXX@10.18.0.2:5060 SIP/2.0
Via: SIP/2.0/UDP 103.78.194.111:5060;branch=z9hG4bKb5ed.60a1de338cb90f4df82438192912494a.0;i=5be1
Max-Forwards: 69
CSeq: 103 BYE
X-Asterisk-HangupCause: Normal Clearing
X-Asterisk-HangupCauseCode: 16
Content-Length: 0
000170: Mar 1 11:34:04.438: //463/56F77C4684F1/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Sun, 01 Mar 2020 22:34:04 GMT
CSeq: 103 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=1042,OS=166720,PR=1026,OR=164160,PL=0,JI=0,LA=0,DU=20
Content-Length: 0
000171: Mar 1 11:34:04.442: //464/56F77C4684F1/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:7711@10.18.0.10:5060 SIP/2.0
Via: SIP/2.0/UDP 10.18.0.2:5060;branch=z9hG4bK1C34D5
Max-Forwards: 70
Timestamp: 1583062444
CSeq: 102 BYE
P-RTP-Stat: PS=1026,OS=164160,PR=1042,OR=166720,PL=0,JI=0,LA=0,DU=20
Content-Length: 0
000172: Mar 1 11:34:04.446: //464/56F77C4684F1/SIP/Msg/ccsipDisplayMsg:
Received:
VG01#SIP/2.0 200 OK
Date: Sun, 01 Mar 2020 11:34:04 GMT
CSeq: 102 BYE
Content-Length: 0
VG01#
000173: Mar 1 11:34:34.219: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 103.78.194.111;branch=z9hG4bK7965.66311472000000000000000000000000.0
CSeq: 10 OPTIONS
Call-ID: 7f65034c01c807ce-1864@103.78.194.111
Max-Forwards: 70
Content-Length: 0
000174: Mar 1 11:34:34.219: //185404173/0B0D0B0D0B0D/SIP/Msg/ccsipDisplayMsg:
Sent:
To: 103.35.128.10:5060>;tag=23D906C-EE8
Date: Sun, 01 Mar 2020 22:34:34 GMT
CSeq: 10 OPTIONS
Content-Length: 0
VG01#
I can get test again later on and get the deb voip ccapi inout too if it helps.
Best regards, Dan103.35.128.10:5060>103.35.128.10:5060>7711>7711>61395xxxxxx>61395xxxxxx>103.78.194.111:5060>103.78.194.111>61418xxxxxx>61395xxxxxx>61395xxxxxx>61418xxxxxx>7711>61418xxxxxx>7711>61418xxxxxx>103.78.194.111:5060>103.78.194.111>61395xxxxxx>61395xxxxxx>61418xxxxxx>7711>2000>2000>7711>61418xxxxxx>7711>61418xxxxxx>61418xxxxxx>7711>61418xxxxxx>61395xxxxxx>61418xxxxxx>61418xxxxxx>61418xxxxxx>61395xxxxxx>103.78.194.111:5060>103.78.194.111>103.35.128.10:5060>103.35.128.10:5060>61395xxxxxx>103.78.194.111:5060>103.78.194.111>61395xxxxxx>61395xxxxxx>7711>7711>2000>2000>7711>103.78.194.111:5060>103.78.194.111>61395xxxxxx>61395xxxxxx>7711>2000>2000>7711>7711>7711>61395xxxxxx>61395xxxxxx>103.78.194.111:5060>103.78.194.111>
