Unable to delete user in Cisco Unity Cxn 9.1.1.10000-32
Saima Harris
I've been trying to delete a user from Unity Cxn but it gives me the following error:
I've followed the steps in the link below, as this seemed to be a known issue, but still could not delete the user.
http://www.cisco.com/en/US/products/ps6509/products_tech_note09186a0080b35d01.shtml
In the CLI got this error when trying to remove user in Unity CLI >>
Column (user004) not found in any table in the query (or SLV is undefined).
Command failed
Any help would be much appreciated.
Saima
Vadym Maliarov
Saima,
Please clarify the following:
1) Did you create users on CUC or imported them from LDAP or via AXL?
2) Do those users have mailbox?
3) What has been done with those users? Did you import them via COBRAS?
4) Did you make any changes on CUC?
5) Send me the output:
utils diagnose test
utils cuc cluster status
run sql select * from ProcessNode
show status
show version active
show version inactive
6) Are all users effected? If not what is the difference between effected and non-effected ones?
7) Choose a user which you aren't able to delete
Run
run cuc dbquery unitydirdb select * from tbl_GlobalUser where alias="..."
//replace ... with the corresponding user alias
br,
Vadym
Hi Vadym,
Thank you for the quick response .
Below please find the output from server.
admin:show status
Host Name    : CUCVM01
Date         : Wed Jun 19, 2013 10:45:59
Time Zone    : Eastern Daylight Time (America/Toronto)
Locale       : en_US.UTF-8
Product Ver  : 9.1.1.10000-11
OS Ver       : 5.0.0.0-2
License MAC  : abbccdccb8aa
Uptime:
10:46:00 up 86 days, 20:59,  1 user,  load average: 0.73, 0.71, 0.56
CPU Idle:   95.02%  System:   00.75%    User:   02.99%
  IOWAIT:   00.50%     IRQ:   00.25%    Soft:   00.50%   Intr/sec: 705.00
Memory Total:        6097216K
        Free:         249844K
        Used:        5847372K
      Cached:        1122780K
      Shared:              0K
     Buffers:          16240K
                        Total            Free            Used
Disk/active        126407836K      116259620K        8843260K (8%)
Disk/inactive      128447676K      119048108K        8094612K (7%)
Disk/logging       516054864K      455507360K       34333444K (8%)
dmin:show version active
Active Master Version: 9.1.1.10000-11
Active Version Installed Software Options:
uc-locale-fr_CA-9.1.0.1-32.cop
ciscocm.refresh_upgrade_v1.1.cop
ciscocm.vmtoolsUpgrade4.1-8.3.2-257589-v14.cop
admin:show version inactive
Inactive Master Version: 8.0.3.22026-1
Inactive Version Installed Software Options:
uc-locale-fr_CA-8.0.1.0-275.cop
admin:utils diagnose test
Log file: platform/log/diag2.log
Starting diagnostic test(s)
test - disk_space          : 2 second(s) left
test - disk_space          : 0 second(s) left
test - disk_space          : Passed (available: 113535 MB, used: 8637 MB)
skip - disk_files          : This module must be run directly and off hours
test - service_manager     : 1 second(s) left
test - service_manager     : 0 second(s) left
test - service_manager     : Passed
test - tomcat              : 10 second(s) left
test - tomcat              : 9 second(s) left
test - tomcat              : 0 second(s) left
test - tomcat              : Passed
test - tomcat_deadlocks    : 5 second(s) left
test - tomcat_deadlocks    : 0 second(s) left
test - tomcat_deadlocks    : Passed
test - tomcat_keystore     : 5 second(s) left
test - tomcat_keystore     : 4 second(s) left
test - tomcat_keystore     : 0 second(s) left
test - tomcat_keystore     : Passed
test - tomcat_connectors   : 30 second(s) left
test - tomcat_connectors   : 0 second(s) left
test - tomcat_connectors   : Passed
test - tomcat_threads      : 5 second(s) left
test - tomcat_threads      : 4 second(s) left
test - tomcat_threads      : 3 second(s) left
test - tomcat_threads      : 2 second(s) left
test - tomcat_threads      : 1 second(s) left
test - tomcat_threads      : 0 second(s) left
test - tomcat_threads      : Passed
test - tomcat_memory       : 30 second(s) left
test - tomcat_memory       : 29 second(s) left
test - tomcat_memory       : 28 second(s) left
test - tomcat_memory       : 27 second(s) left
test - tomcat_memory       : 26 second(s) left
test - tomcat_memory       : 25 second(s) left
test - tomcat_memory       : 24 second(s) left
test - tomcat_memory       : 23 second(s) left
test - tomcat_memory       : 22 second(s) left
test - tomcat_memory       : 21 second(s) left
test - tomcat_memory       : 20 second(s) left
test - tomcat_memory       : 19 second(s) left
test - tomcat_memory       : 0 second(s) left
test - tomcat_memory       : Failed - Tomcat's memory usage is unusually high.  Use the 'utils diagnose module tomcat_heapdump' command to generate a memory dump for further analysis.  Note, creating the memory dump will increase CPU usage and disk I/O for several minutes.  Web services will also be disabled while the memory dump is generated.
test - tomcat_sessions     : 5 second(s) left
test - tomcat_sessions     : 4 second(s) left
test - tomcat_sessions     : 0 second(s) left
test - tomcat_sessions     : Passed
skip - tomcat_heapdump     : This module must be run directly and off hours
test - validate_network    : 300 second(s) left
test - validate_network    : 299 second(s) left
test - validate_network    : 0 second(s) left
test - validate_network    : Passed
test - raid                : 10 second(s) left
test - raid                : 0 second(s) left
test - raid                : Passed
test - system_info         : 60 second(s) left
test - system_info         : 59 second(s) left
test - system_info         : 58 second(s) left
test - system_info         : 57 second(s) left
test - system_info         : 56 second(s) left
test - system_info         : 55 second(s) left
test - system_info         : 0 second(s) left
test - system_info         : Passed (Collected system information in diagnostic log)
test - ntp_reachability    : 5 second(s) left
test - ntp_reachability    : 0 second(s) left
test - ntp_reachability    : Passed
test - ntp_clock_drift     : 5 second(s) left
test - ntp_clock_drift     : 0 second(s) left
test - ntp_clock_drift     : Passed
test - ntp_stratum         : 5 second(s) left
test - ntp_stratum         : 0 second(s) left
test - ntp_stratum         : Passed
skip - sdl_fragmentation   : This module must be run directly and off hours
skip - sdi_fragmentation   : This module must be run directly and off hours
test - ipv6_networking     : 60 second(s) left
test - ipv6_networking     : 0 second(s) left
test - ipv6_networking     : Passed
Diagnostics Completed
admin:show cuc cluster status
ACE_File_Lock::ACE_File_Lock: Permission denied /dev/shm/CCM_GENstatusLock_0
Server Name   Member ID  Server State  Internal State  Reason
cucvm01  0          Primary       Pri Active      Normal
gucvm01  1          Secondary     Sec Active      Normal
SERVER                 ID STATE    STATUS     QUEUE  CONNECTION CHANGED
g_ciscounity_pub      100 Active   Local           0
g_ciscounity_sub1     101 Active   Connected    7184 Mar 24 13:48:49
SERVERS
Server            Peer              ID   State    Status     Queue  Connection Changed
g_ciscounity_pub  g_ciscounity_pub  100  Active   Local      0
g_ciscounity_sub1 g_ciscounity_pub  100  Active   Connected  549    Mar 24 13:48:50
                  g_ciscounity_sub1 101  Active   Local      0
STATE
Source            ER               Capture          Network          Apply
                  State            State            State            State
g_ciscounity_pub  Active           Running          Running          Running
g_ciscounity_sub1 Active           Running          Running          Running
admin:run cuc dbquery unitydirdb select* from tbl_GlobalUser where alias=ghar004
Column (ghar004) not found in any table in the query (or SLV is undefined).
Command failed
Please advise if you notice anything wrong.
Saima
Saima,
Could you please answer all my questions?
Please, send the screen of the user which you are trying to delete (from CUC Admin page)
br,
Vadym
