Route calls without a called number
George Thomas
Level 10
Level 10
Is it possible to route calls to an extension in CME where the called number is not present in the ISDN signaling.
Thanks in advance?
Please rate useful posts.
6 Replies 6
Chris Deren
If there is no called number then how does the call get to your system?
Chris
The provider gets it to the system somehow.
Hi George,
It's possible route all call to an extension using the Conection-plar command:
Voice-port 1/0:1
 connection plar 2000
!--- This command starts a PLAR switched
!--- VoIP call that uses digits (2000)
 !--- to match a VoIP dial-peer when the voice-port 1/0:1 goes off-hook.
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
__________________________________________________
Unfortunately that is not possible since only the main number doesnt have the called number, other DIDs work fine.
Just get a DID for the main number, that should be a easy task for the service provider.
bkhanal1971
Level 3
Level 3
You should be able to do it using translation rules.
