Unable to edit publisher hostname on CER
amit.rajput
We want to change our CER pubisher IP address and hostname on CER.
I logged into CER sub OS admin > Settings > IP > Publisher
and tried changing the Pub hostname and IP address but looks like hostname field is not editable, it's not grayed out but you can't type anything, we can change the IP address though.
Tried changing from CER CLI but if I type the command set network hostname, it says invalid command.
CER version - 9.0.1
Your help would be highly appreciated.
Amit
Rajan
Hi Amit,
Have you changed the IP and hostname on the publisher using the below procedure and rebooted the cluster ?
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cer/11_0/english/administration/guide/CER0_BK_C50B9FF0_00_cisco-emergency-responder-administration-guide-1101/ip_address_and_hostname.pdf?bcsi_scan_242f14fdc4f33f94=ulEmNbQIpZJhuxbMFOuldGIs4DgTAAAAGDz7Qw==&bcsi_scan_filename=ip_address_and_hostname.pdf
Rajan
Pls rate all useful posts
