Unable to find the option to select multiple messages in PCA inbox to delete.
chandra_827
I am not sure what is missing and all the default settings are made for the account undeliversablemessagemailbox and still i dont see the option to select multiple for deleting from the Inbox of the Cisco PCA Inbox.
Please let me know if some things needs to be checked.
Chandra Sekhar M.N.S
testeven
Hi Chandra,
What's the Unity Connection version you are using? I'm asking 'cause there is a known bug for
8.X versions:
CSCtw49703    Web Inbox should allow multiple messages to be deleted at one time
Symptom:
Not able to delete multiple messages at one time with web inbox in UC 8.x
Conditions:
This feature existed in 7.x but not in web inbox 8.x
The bug is considered a product enhancement and will be addressed in Unity Connection release
9.X.
Tere.
If you find this post helpful, please rate!
Regards, Tere. If you find this post helpful, please rate! :)
testeven
Hi Chandra,
8.X versions:
Symptom:
Conditions:
9.X.
Tere.
Thank you for the note. the below is the version i am in. So until version 9 Cisco does not have any idea of fixing this ?
Version 8.5.1ES47.12024-47
