12-26-2012 12:20 AM - edited 03-16-2019 02:52 PM
Hi All,
We're migrating from CM5 to CUCM8.6, i noticed that phones that have been migrated to CUCM8.6 were unable to Hold, Transfer or Add to Conference while in a PSTN call. We're using H.323 gateway and CUCM MTP.
Our VG config;
resource-pool disable
no aaa new-model
resource policy
clock timezone GMT 8
tdm clock priority 1 7/0
tdm clock priority 2 7/1
ip cef
isdn switch-type primary-net5
isdn housekeeping free
voice rtp send-recv
voice class codec 1
codec preference 1 g711ulaw
interface Loopback0
no ip address
interface GigabitEthernet0/0
ip address 192.168.2.6 255.255.255.0
duplex full
speed 1000
no negotiation auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.2.6
interface GigabitEthernet0/1
ip address 10.1.1.1 255.255.255.0
shutdown
duplex auto
speed auto
negotiation auto
interface Serial0/0
ip address 172.16.0.2 255.255.255.0
ip nbar protocol-discovery
load-interval 60
clock rate 2000000
no dce-terminal-timing-enable
invert txclock
no fair-queue
interface Serial7/0
no ip address
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface Serial7/0:15
no ip address
encapsulation hdlc
isdn incoming-voice data
isdn map address .* plan isdn type subscriber
isdn send-alerting
no cdp enable
interface Serial7/1:15
no ip address
encapsulation hdlc
isdn send-alerting
no cdp enable
interface Serial7/2:15
no ip address
encapsulation hdlc
isdn send-alerting
no cdp enable
interface Serial7/3:15
no ip address
encapsulation hdlc
isdn send-alerting
no cdp enable
interface Serial7/4:15
no ip address
encapsulation hdlc
isdn send-alerting
no cdp enable
interface Serial7/5:15
no ip address
encapsulation hdlc
isdn send-alerting
no cdp enable
interface Serial7/6:15
no ip address
encapsulation hdlc
isdn send-alerting
no cdp enable
interface Serial7/7:15
no ip address
encapsulation hdlc
isdn send-alerting
no cdp enable
no ip http server
control-plane
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
dial-peer voice 100 voip
description ***Connection to CCM-PUB***
destination-pattern .T
progress_ind setup enable 3
session target ipv4:192.168.2.11
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 101 voip
description ***Connection to CCM-SEC***
session target ipv4:192.168.2.12
codec g711ulaw
no vad
dial-peer voice 102 voip
description ***Connection to CUCM8***
session target ipv4:192.168.2.21
codec g711ulaw
no vad
no dial-peer outbound status-check pots
gateway
media-inactivity-criteria all
timer receive-rtcp 6
timer receive-rtp 1200
ss7 mtp2-variant Bellcore 0
ss7 mtp2-variant Bellcore 1
ss7 mtp2-variant Bellcore 2
ss7 mtp2-variant Bellcore 3
alias exec traffic show ip nbar protocol-discovery stats bit-rate top-n 5
scheduler allocate 10000 400
end
Thanks in advance for any feedback. Thank.
Solved! Go to Solution.
12-26-2012 01:41 AM
Hi Mohd. Hidzwan,
Glad to hear hold and transfer are now working after unchecking MTP (still dont know why you had it checked to begin with). Looks like you uploaded the CTI Manager trace file. I require the detailed CUCM SDI trace files which cover the test call. Considering that only conference calls are failing, are you able to place a conference call internally i.e. all 3 parties are IP phones? Did you make sure that the conference media resource is added to the MRG/MRGL of the IP phones and gateway config page?
Harmit.
12-26-2012 01:01 AM
Hi Mohd. Hidzwan,
Why are you using MTP for these calls? Do you get an error when you try to do a hold / transfer / conference or does the call drop? Can you provide detailed CUCM SDI and SDL traces for one such call where hold / transfer / conference fails along with the call details and timestamp of the call?
Harmit.
12-26-2012 01:33 AM
Ok. Now i've unchecked the MTP required in Gateway Configuration page. Now i'm able to use Hold & Transfer. However, once i press Conference it prompt No Conference Bridge.
Please find attached log per request. I tried the call between extension 5756 and mobile phone 0176065415. It should be last call from the logs
12-26-2012 01:41 AM
Hi Mohd. Hidzwan,
Harmit.
12-26-2012 11:52 PM
Thanks Harmit,
Yes it seems the root cause came from media resource configuration. After further investigation and verification, we managed to solve it. Thanks a lot.
12-27-2012 12:51 AM
My pleasure! Glad to know that did the trick! :-)
Happy New Year!
Harmit.
