Unable to install CUCM10.5.2 on VMware workstation 11.(Critical Error)
krishnashk
Hi Guys
I have been trying to install CUCM10.5.2 on vmware workstation 11 on pc for lab. I have been getting the same error.(image attached)
I have tried using the ova template from cisco, but still failed.
Anything I am missing ?
2 Accepted Solutions
Rajan
Hi Krishna,
Have you verified MD5 checksum of the ISO file ?
Rajan
Ronak Agarwal
Krishna,
Try using the link below for help:
http://vonclawson.blogspot.in/2015/04/cucm-1052-install-on-vmware-workstation.html
Ronak Agarwal
6 Replies 6
Rajan
Hi Krishna,
Rajan
Hi Rajan
Thank your  for the response.
The iso I downloaded from cisco was not Bootable. I  converted the iso to Bootable I think that might change the hash value.
I should  compare  hash before  converting to Bootable?
the checksum value was for the downloaded file. So yes, pls check it before converting to bootable image.
Hi Rajan
I just verified the hash.  It is correct.
The iso was on a remote drive . Copied it to a local drive and tried worked fine.
Thanks guys!
Ronak Agarwal
Krishna,
Ronak Agarwal
