IP Telephony and Phones
Labels
Hi Guys, We are encountering an issue with BLF Speed Dial pickup and the error that we are receiving is "Temporary Failure" when the  two IP Phone belongs to different Pickup group and "Key is not active" if phone A has a pickup group while phone B ...
HI , After the phone 9951 is connected with switch, it shows "Phone Not Registered". I checked connection several times and they are ok. The switch can see the phone through show cdp neighbor. I configured cucm based on normal process. Anyone can giv...
wfqk by Level 5
  • 569 Views
  • 10 replies
How we can set max call duration just for outgoing calls to PSTN only? Phone Device >>>>> Call manager server V10 >>> MGCP GW>>> FXO >>> PSTN   I can find max call duration, but it is for all call in Cisco call manager server. and all phones So I ne...
zeincisco by Level 1
  • 553 Views
  • 3 replies
Hi Guys I wanted to try mediasense in my lab. Tried installing the 8.5.4 on VMware workstation 11 using the ova template from cisco. Installation was fine. But was unable to get the login page. Tried restarting the Cisco Tomcat service. no luck. Als...
i took one at ldlc in france where it was in the middle of others ip-phonemy idea was to use it with a viasat modem that is for satelitte web access by now after reading few documents : i am unable to set the ip of the phone , i have no idea how i ca...
grml4d001 by Level 1
  • 1234 Views
  • 7 replies
We are experiencing problems with sporadic "dead air calls" on 8945 phones on Cisco's contact Center.  I'm trying to determine if its an issue with network switch configuration.  The 8945 is getting 500ms Latency on stream-1 when the client looks lik...
