Unable to install RTMT for v14, I have 12.5 installed
dotttts
I tried java 20 and 17 no dice.
I download and run as admin the ccmservrtmtplugin for v14. I get error: This application has Unexpectedly Quit. Invocation of this Java Application has caused an InvocationTargetException. This application will now exit. (LAX)
Details:
Flexeraaxd$aaa: Windows DLL failed to load
at Flexeraaxd.af(Unknown Source)
at Flexeraaxd.aa(Unknown Source)
at com.zerog.ia.installer.LifeCycleManager.init(Unknown Source)
at com.zerog.ia.installer.LifeCycleManager.executeApplication(Unknown Source)
at com.zerog.ia.installer.Main.main(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.zerog.lax.LAX.launch(Unknown Source)
at com.zerog.lax.LAX.main(Unknown Source)
I was running java:
C:\>java -version
java version "1.8.0_102"
Java(TM) SE Runtime Environment (build 1.8.0_102-b14)
Java HotSpot(TM) 64-Bit Server VM (build 25.102-b14, mixed mode)
now running:
C:\Windows>java -version
java version "1.8.0_351"
Java(TM) SE Runtime Environment (build 1.8.0_351-b10)
Java HotSpot(TM) 64-Bit Server VM (build 25.351-b10, mixed mode)
rtmt for 12.5 works fine kinda, i have to launch the bat from the JRtmt folder.
Thanks in advance,
Mike Parker
