Unable to Ping Call Manger IP Address over VPN
Vikrant Ambhore
Hello All,
I have done  IPSEC VPN  setup between 1861 & UC520, There is two BVI interface on UC-520 BVI-1 (10.1.1.1) & BVI-2 (192.168.2.1)
192.168.2.1(BVI-2) is for Data means for access Internet from All system in LAN & 10.1.1.1(BVI-1) is for TFTP which is for IP Phones.
My Call manager &  Telephony-Service is configured on UC-520, that's why I need to ping both BVI Interface of UC-520 from Cisco 1861,
I need to ping  192.168.2.0 from VLAN 1 of 1861 for Access resources over VPN & need to ping 10.1.1.1 for download firmware which is necessary for IP phone.
Now I'm able to ping 192.168.2.0 from VLAN-1 but unable to ping 10.1.1.1 from Both VLAN
I don't want to use Internet on VLAN-100 but need to ping 10.1.1.1 from VLAN-100 of 1861
I hope anyone will understand my Issue.
Can anyone suggest me what  need to be done for solve this issue?
I attached running configuration of both router with this comment
Vikrant
fkarami
Make sure you are not NATing the address range of the addresses that you are trying to reach. To test, just do a tracerroute and see whether your traffic is going through the internet or jumps to the otherside of the network that you have the site to site VPN. You would want to encrypt and send the data directly to the otherside and that should be reflected in the access list.
Hope this helps,
Farbod
