Unable to place call on calls on hold - SIP Trunk from CUCM to CUBE and from CUBE to ISTP
Hi Cisco Community,
I have a SIP Trunk setup between the CUCM and CUBE and another SIP Dial Peers from the CUBE to the ITSP. All incoming/outgoing calls, DTMF-Relay works well except one thing which is the ability to hold the call.
On the SIP Trunk from the CUCM to the CUBE, I did not select “MTP” because when I do so, I am forced to select my preferred MTP codec which when selected G.729/G.729a, all my outgoing calls goes out using G.729r8. This codec works well for most of the calls until the ITSP replies back with G.729br8. When this condition occur, my call simply fails (this is very intermittent and only some random numbers).
That said, I have some issues with DTMF Relay when I select MTP on the SIP Trunk. DTMF Relay only works if the call is G.729r8 all the way from the CUCM to the ITSP. If the ITSP replies back with G.729br8, the call might established but will simply be “voice-only”.
The current setup is no MTP is selected and everything is working perfectly. I am happy with that until I place a call on hold, which when I do so, the call immediately terminate. Could you please help me understand why?
I have all media resources configured such as G.729r8 MTP, G.729br8 MTP, G.711u MTP, Transcoding with all codecs, etc. All MRG and MRGL are configured on all devices and SIP Trunks.
Below is an example of a call that is connected with the current setup:
Note:
IP: 10.18.81.2 (CUBE)
IP: 10.18.81.11 (CUCM SUB)
IP: 10.111.111.254 (ITSP SBC)
PM-HO-VG-01#
PM-HO-VG-01#
Nov 30 11:44:29.938: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:0862000000@10.18.81.2:5060 SIP/2.0
Via: SIP/2.0/UDP 10.18.81.11:5060;branch=z9hG4bK2e72063a5aba5d
From: "Bianca Africa" <sip:0218091323@10.18.81.11>;tag=9082578~cdf4c5a6-dd2b-4c71-bca0-b262ad997720-44517224
To: <sip:0862000000@10.18.81.2>
Date: Sun, 30 Nov 2014 11:44:29 GMT
Call-ID: 3cd5d200-47b1031d-64cfc-b51120a@10.18.81.11
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM9.1
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <sip:10.18.81.11:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Cisco-Guid: 1020645888-0000065536-0000124117-0189862410
Session-Expires:  1800
Contact: <sip:0218091323@10.18.81.11:5060>
Max-Forwards: 70
Content-Length: 0
Nov 30 11:44:29.942: //64510/3CD5D2000001/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.2.4.M5
Content-Length: 0
Nov 30 11:44:29.946: //64511/3CD5D2000001/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:0862000000@10.111.111.254:5060 SIP/2.0
Via: SIP/2.0/UDP 10.18.81.2:5060;branch=z9hG4bK3EC72218
From: "Bianca Africa" <sip:27218091323@10.18.81.2>;tag=3C364D44-9E2
To: <sip:0862000000@10.111.111.254>
Call-ID: 143471FC-77BD11E4-8E3EF86B-3406F8AC@10.18.81.2
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M5
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1417347869
Contact: <sip:27218091323@10.18.81.2:5060>
Call-Info: <sip:10.18.81.2:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Max-Forwards: 69
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 301
v=0
o=CiscoSystemsSIP-GW-UserAgent 7676 6958 IN IP4 10.18.81.2
s=SIP Call
c=I
PM-HO-VG-01#N IP4 10.18.81.2
t=0 0
m=audio 22256 RTP/AVP 18 0 8 101
c=IN IP4 10.18.81.2
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=yes
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
Nov 30 11:44:29.950: //64511/3CD5D2000001/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Nov 30 11:44:30.658: //64511/3CD5D2000001/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Session Progress
To: <sip:0862000000@10.111.111.254>;tag=71913148-1417348035284
CSeq: 101 INVITE
Supported:
Contact: <sip:0862000000@10.111.111.254:5060;transport=udp>
Session: Media
Allow: ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,NOTIFY,UPDATE
X-BroadWorks-Correlation-Info: bbf94839-a234-4237-95e6-a7037322f0f4
Content-Length: 355
v=0
o=BroadWorks 316169737 1 IN IP4 10.111.111.254
s=-
c=IN IP4 10.111.111.254
t=0 0
m=audio 20074 RTP/AVP 18 101 100
a=fmtp:101 0-15
a=rtpmap:100 X-NSE/8000
a=fmtp:100 200-202
a=X-sqn:0
a=X-cap: 1 audio RTP/AVP 100
a=X-cpar: a=rtpmap:100 X-NSE/8000
a=X-cpar: a=fmtp:100 200-202
a=X-cap: 2 image udptl t38
Nov 30 11:44:30.662: //64510/3CD5D2000001/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 183 Session Progress
To: <sip:0862000000@10.18.81.2>;tag=3C365010-1E42
CSeq: 101 INVITE
Contact: <sip:0862000000@10.18.81.2:5060>
Supported: sdp-anat
Content-Length: 289
v=0
o=CiscoSystemsSIP-GW-UserAgent 7965 2747 IN IP4 10.18.81.2
s=SIP Call
c=IN IP4 10.18.81.2
t=0 0
m=audio 22350 RTP/AVP 18 101 19
c=IN IP4 10.18.81.2
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
Nov 30 11:44:31.226: //64511/3CD5D2000001/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 101 INVITE
Supported:
Session: Media
PM-HO-VG-01#4839-a234-4237-95e6-a7037322f0f4
Content-Length: 355
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=fmtp:100 200-202
a=X-sqn:0
Nov 30 11:44:31.630: //64511/3CD5D2000001/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported:
Accept: application/media_control+xml,application/sdp,application/xml
Content-Length: 355
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=fmtp:100 200-202
a=X-sqn:0
Nov 30 11:44:31.630: //64511/3CD5D2000001/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x3D7B1458
State of The Call        : STATE_ACTIVE
TCP Sockets Used         : NO
Calling Number           : 27218091323
Called Number            : 0862000000
Source IP Address (Sig  ): 10.18.81.2
Destn SIP Req Addr:Port  : 10.111.111.254:5060
Destn SIP Resp Addr:Port : 10.111.111.254:5060
Destination Name         : 10.111.111.254
Nov 30 11:44:31.630: //64511/3CD5D2000001/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : g729br8
Negotiated Codec Bytes   : 20
Nego. Codec payload      : 18 (tx), 18 (rx)
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101 (tx), 101 (rx)
Source IP Address (Media): 10.18.81.2
Source IP Port    (Media): 22256
Destn  IP Address (Media): 10.111.111.254
Destn  IP Port    (Media): 20074
Orig Destn IP Address:Port (Media): [ - ]:0
Sent:
ACK sip:0862000000@10.111.111.254:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.18.81.2:5060;branch=z9hG4bK3EC81D00
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Nov 30 11:44:31.634: //64510/3CD5D2000001/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 289
v=0
s=SIP Call
c=IN IP4 10.18.81.2
t=0 0
c=IN IP4 10.18.81.2
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
Nov 30 11:44:31.726: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:0862000000@10.18.81.2:5060 SIP/2.0
Via: SIP/2.0/UDP 10.18.81.11:5060;branch=z9hG4bK2e72075e3a02c1
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 236
v=0
o=CiscoSystemsCCM-SIP 9082578 1 IN IP4 10.18.81.11
s=SIP Call
c=IN IP4 10.18.80.40
b=TIAS:8000
b=AS:8
t=0 0
m=audio 21928 RTP/AVP 18 101
a=ptime:20
a=fmtp:101 0-15
Nov 30 11:44:31.730: //64510/3CD5D2000001/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x0x3D816D70
Calling Number           : 0218091323
Destn SIP Req Addr:Port  : 10.18.81.11:5060
Destn SIP Resp Addr:Port : 10.18.81.11:5060
Destination Name         : 10.18.81.11
Nov 30 11:44:31.730: //64510/3CD5D2000001/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 22350
Destn  IP Address (Media): 10.18.80.40
Destn  IP Port    (Media): 21928
PM-HO-VG-01#
Media Stream             : 1
PM-HO-VG-01#sh sip
PM-HO-VG-01#sh sip-ua call
PM-HO-VG-01#sh sip-ua calls
Total SIP call legs:2, User Agent Client:1, User Agent Server:1
SIP UAC CALL INFO
Call 1
SIP Call ID                : 143471FC-77BD11E4-8E3EF86B-3406F8AC@10.18.81.2
   State of the call       : STATE_ACTIVE (7)
   Substate of the call    : SUBSTATE_NONE (0)
   Bit Flags               : 0xC04018 0x10000100 0x0
   CC Call ID              : 64511
   Destn SIP Req Addr:Port : [10.111.111.254]:5060
   Destn SIP Resp Addr:Port: [10.111.111.254]:5060
   Number of Media Streams : 1
   Number of Active Streams: 1
   RTP Fork Object         : 0x0
   Media Mode              : flow-through
   Media Stream 1
     State of the stream      : STREAM_ACTIVE
     Stream Call ID           : 64511
     Stream Type              : voice+dtmf (0)
     Stream Media Addr Type   : 1
     Negotiated Codec         : g729br8 (20 bytes)
     Codec Payload Type       : 18
     Negotiated Dtmf-relay    : rtp-nte
     Dtmf-relay Payload Type  : 101
     QoS ID                   : -1
     Local QoS Strength       : BestEffort
     Negotiated QoS Strength  : BestEffort
     Negotiated QoS Direction : None
     Local QoS Status         : None
     Media Source IP Addr:Port: [10.18.81.2]:22256
     Media Dest IP Addr:Port  : [10.111.111.254]:20074
Options-Ping    ENABLED:NO    ACTIVE:NO
   Number of SIP User Agent Client(UAC) calls: 1
SIP UAS CALL INFO
Call 1
SIP Call ID                : 3cd5d200-47b1031d-64cfc-b51120a@10.18.81.11
   Bit Flags               : 0xC0401E 0x10000100 0x80004
   CC Call ID              : 64510
   Destn SIP Req Addr:Port : [10.18.81.11]:5060
   Destn SIP Resp Addr:Port: [10.18.81.11]:5060
   Media Stream 1
     Stream Call ID           : 64510
     Stream Type              : voice+dtmf (1)
     QoS ID                   : -1
     Media Source IP Addr:Port: [10.18.81.2]:22350
     Media Dest IP Addr:Port  : [10.18.80.40]:21928
   Number of SIP User Agent Server(UAS) calls: 1
PM-HO-VG-01#
PM-HO-VG-01#
PM-HO-VG-01#
As you can see, the call is connected and everything is working perfectly. When I press the hold button, here is what I get:
NOTE: I have # debug ccsip messages and #debug ccsip calls (running)
PM-HO-VG-01#
PM-HO-VG-01#
Nov 30 11:44:49.210: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.18.81.11:5060;branch=z9hG4bK2e720852ab8b92
Date: Sun, 30 Nov 2014 11:44:49 GMT
Min-SE:  1800
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 180
Supported: Geolocation
Content-Length: 244
v=0
o=CiscoSystemsCCM-SIP 9082578 2 IN IP4 10.18.81.11
s=SIP Call
c=IN IP4 0.0.0.0
b=TIAS:8000
b=AS:8
t=0 0
a=ptime:20
a=inactive
a=fmtp:101 0-15
Nov 30 11:44:49.218: //64510/3CD5D2000001/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 102 INVITE
Content-Length: 0
Nov 30 11:44:49.218: //64511/3CD5D2000001/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:0862000000@10.111.111.254:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.18.81.2:5060;branch=z9hG4bK3EC9241
Min-SE:  1800
CSeq: 102 INVITE
Max-Forwards: 70
Timestamp: 1417347889
Expires: 180
Content-Length: 271
v=0
o=CiscoSystemsSIP-GW-UserAgent 7676 6959 IN IP4 10.18.81.2
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
m=audio 22256 RTP/AVP 18 101
c=IN IP4 0.0.0.0
a=inactive
a=fmtp:101 0-15
a=ptime:20
Nov 30 11:44:49.278: //64511/3CD5D2000001/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported:
Content-Length: 360
v=0
o=BroadWorks 316169737 2 IN IP4 10.111.111.254
s=-
c=IN IP4 0.0.0.0
t=0 0
a=fmtp:101 0-15
a=fmtp:100 200-202
a=X-sqn:0
a=inactive
Nov 30 11:44:49.278: //64511/3CD5D2000001/SIP/Call/sipSPICallInfo:
Nov 30 11:44:49.278: //64511/3CD5D2000001/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Destn  IP Address (Media): 0.0.0.0
Nov 30 11:44:49.282: //64511/3CD5D2000001/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.18.81.2:5060;branch=z9hG4bK3ECA2633
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
Nov 30 11:44:49.282: //64510/3CD5D2000001/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 271
v=0
o=CiscoSystemsSIP-GW-UserAgent 7965 2748 IN IP4 10.18.81.2
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
c=IN IP4 0.0.0.0
a=inactive
a=fmtp:101 0-15
a=ptime:20
Nov 30 11:44:49.282: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.18.81.11:5060;branch=z9hG4bK2e72094953dfea
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
Nov 30 11:44:49.290: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.18.81.11:5060;branch=z9hG4bK2e720a6918040f
Min-SE:  1800
CSeq: 103 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 0
Nov 30 11:44:49.294: //64510/3CD5D2000001/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 103 INVITE
Content-Length: 0
Nov 30 11:44:49.294: //64511/3CD5D2000001/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.18.81.2:5060;branch=z9hG4bK3ECB16F3
Supported: timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
CSeq: 103 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 0
Nov 30 11:44:49.338: //64511/3CD5D2000001/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 103 INVITE
Supported:
Content-Length: 306
v=0
o=BroadWorks 316169737 3 IN IP4 10.111.111.254
s=-
t=0 0
a=fmtp:101 0-15
a=X-sqn:0
Nov 30 11:44:49.342: //64510/3CD5D2000001/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 2
PM-HO-VG-01#00 OK
CSeq: 103 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 289
v=0
o=CiscoSystemsSIP-GW-UserAgent 7965 2749 IN IP4 10.18.81.2
s=SIP Call
c=IN IP4 10.18.81.2
t=0 0
c=IN IP4 10.18.81.2
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
Nov 30 11:44:49.350: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.18.81.11:5060;branch=z9hG4bK2e720b594cd517
Max-Forwards: 70
CSeq: 103 ACK
Content-Length: 213
v=0
o=CiscoSystemsCCM-SIP 9082578 3 IN IP4 10.18.81.11
s=SIP Call
c=IN IP4 10.18.81.10
t=0 0
m=audio 4000 RTP/AVP 18
a=X-cisco-media:umoh
a=ptime:20
a=fmtp:18 annexb=no
a=sendonly
Nov 30 11:44:49.354: //64510/3CD5D2000001/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:0218091323@10.18.81.11:5060 SIP/2.0
Via: SIP/2.0/UDP 10.18.81.2:5060;branch=z9hG4bK3ECC55
From: <sip:0862000000@10.18.81.2>;tag=3C365010-1E42
To: "Bianca Africa" <sip:0218091323@10.18.81.11>;tag=9082578~cdf4c5a6-dd2b-4c71-bca0-b262ad997720-44517224
Max-Forwards: 70
CSeq: 101 BYE
Reason: Q.850;cause=86
P-RTP-Stat: PS=874,OS=17480,PR=872,OR=17440,PL=0,JI=0,LA=0,DU=17
Content-Length: 0
Nov 30 11:44:49.354: //64511/3CD5D2000001/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:0862000000@10.111.111.254:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.18.81.2:5060;branch=z9hG4bK3ECD1ECD
Max-Forwards: 70
CSeq: 104 BYE
Reason: Q.850;cause=65
P-RTP-Stat: PS=872,OS=17440,PR=952,OR=19040,PL=0,JI=0,LA=0,DU=17
Content-Length: 0
Nov 30 11:44:49.374: //64511/3CD5D2000001/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Race Condition
CSeq: 104 BYE
Content-Length: 0
Nov 30 11:44:49.374: //64511/3CD5D2000001/SIP/Call/sipSPICallInfo:
State of The Call        : STATE_DEAD
Nov 30 11:44:49.374: //64511/3CD5D2000001/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Disconnect Cause (CC)    : 65
Disconnect Cause (SIP)   : 200
Nov 30 11:44:49.406: //64510/3CD5D2000001/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 BYE
Content-Length: 0
Nov 30 11:44:49.406: //64510/3CD5D2000001/SIP/Call/sipSPICallInfo:
Nov 30 11:44:49.406: //64510/3CD5D2000001/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Disconnect Cause (CC)    : 86
PM-HO-VG-01#
11 Replies 11
Manish Prasad
Level 5
Level 5
Hi Johnny,
SIP messaging is correct from CUCM side and when CUCM try to insert moh stream in the call its gets disconnected and disconnection comes from CUBE side.
Sent:
Max-Forwards: 70
CSeq: 101 BYE
Content-Length: 0
One thing comes to my mind is when CUCM send ack with codes details as below
t=0 0
a=ptime:20
a=fmtp:18 annexb=no
a=sendonly
It send annexb=no . So can you check codec applied to dial-peer between CUBE and CUCM , if its contains only G.729b then add more g729 codecs to that dial-peer using voice class codec.
Manish
Hello Manish,
Thanks so much for your mail.
Here is what I picked up last night when I was having a look into the problem:
As you can see in my first set of logs, when the call was active, the codec being negotiated between the ITSP and the CUBE was set to G.729br8.
When the call is put on hold and the CUCM respond back to with an ACK message, the codec being sent to the CUBE is G.728r8.
All my voice class codec contains both G.729r8 first and then G.729br8 as the second codec preference.
What is funny is this:
Last night any incoming or outgoing calls that negotiated G.729r8 when active, when you put those calls on hold, they do not drop at all. You are able to put them on hold but when you resume, the audio does not resume and the call end automatically after couple of seconds.
I have managed to have this solution works with lack by having the following:
When I maintain SIP all the way from CUCM --> SIP Trunk --> CUBE --> SIP Trunk --> ITSP, all incoming and outgoing calls are working fine and DTMF relay also works well. The only thing lacking here is when you put the call on hold, it fails automatically.
When I have H.323 between the CUCM and CUBE and SIP from the CUBE to the ITSP, all incoming and outgoing calls works fine and I am also able to place the call on hold no matter which codec is negotiated such as G.729r8 or G.729br8. The only issue with this setup is DTMF relay is being negotiated as inband, hence DTMF relay does not work with this setup at all.
Please advise.
I would suggest keep SIP protocol in all call leg if you are peering with Telco through SIP.
As you said now calls are working on hold but fails when you resume it , can you attach ccsip logs from cube for this call failure scenario.
Manish
Hi Manish,
Again, excellent feedback. Much appreciated.
I will try the commands suggested above and see if I can get DTMF to work correctly while interworking H.323 and SIP.
But my ultimate goal is to have SIP all way from the CUCM to the CUBE and from the CUBE to the ITSP.
If I enable SIP Early Offer with MTP on the CUCM going to the CUBE, all SIP Invite sent from the CUCM to the CUBE uses G.729r8 as the codec and once the call is established using G.729r8 should the ITSP reply with that codec, the call succeed and I am able to see an active MTP session using G.729 when I issue the command # show sccp connections.
One thing that I saw is that my ITSP love so much sending G.729br8 most of the times, so even if using SIP EO with MTP on the SIP Trunk to the CUBE, when I sent my INVITE out from the CUCM to the CUBE using G.729r8, specially on call center numbers such as 0800 numbers, you will see that the call established but the codec being negotiated is G.729br8 which is voice only (missing DTMF).
I will be doing some intensive test again later on this week and will send the logs.
Here is my question to both of you:
Which is the best way of having a proper SIP to SIP setup all the way that will not pose any problem?
Do I have to enable Early Offer on the SIP Profile used by the CUBE SIP Trunk or should I use the normal Standard SIP Profile? Do I need to enable MTP on my CUBE SIP Trunk or not?
From the CUBE point of view, I have a voice class codec that support G.729r8 or G.729br8 and the DTMF Relay method supported by the ITSP is RFC 2833.
I will send more logs for each scenario. I think that we are getting close to the resolution of this problem.
Thanks again for your support fellows.
You asked which version of CUCM I am running and its version: 9.1.2.11900-12
The recommended approach is to use DO to EO. Ie configure your CUCM to do DO to CUBE and CUBE to do EO to ITSP. This removes the need to use MTP for EO on the sip trunk. The only place you should enable EO support is the parameter on the sip profile that says " enable eo support for voice and video insert MTP if needed"
You should enable EO on your CUBE with the ff: command
voice service voip
sip
early-offer forced
The codec that your ITSP will use for each call will depend on your codec preference in your voice class config applied to the dial-peer
With this INVITE sent to the ITSP, your preference says use G729br8 first, then G711ulaw 2nd, then G711alaw as the 3rd option.
c=IN IP4 10.18.81.2
The ITSP should honour your codec preference. If you remove G729br8 from your codec list, then your ITSP will not negotiate that codec at all and that's what I suggested. Your voice class codec will look like this..
voice class codec 1
 codec preference 1 g729r8
 codec preference 2 g711ulaw
 codec preference 3 g711alaw
Please rate all useful posts
Hello Ayodeji,
how are you ? I enjoy reading your thoughtful posts.
" This removes the need to use MTP for EO on the sip trunk. The only place you should enable EO support is the parameter on the sip profile that says " enable eo support for voice and video insert MTP if needed"
-- This seems contradictory...if CUBE is already doing DO-EO then why would the SIP trunk profile need the " enable eo support for voice and video insert MTP if needed"
Are you saying for call-hold-resume to work, we need EARLY offer towards the ITSP in addition to the CUCM SIP trunk setting " enable eo support for voice and video insert MTP if needed" ?
thanks,Padhu
Padhu,
Thanks for the compliments :)
In some scenarios or call flows you do require EO from CUCM. In previous versions of CUCM there was no way to enable EO for certain call types and not for others. You had to use a MTP to send EO out. With this feature, you will be able to use EO only for calls that absolute need them and MTP will be inserted if required. Another benefit of this is that some phone models do generate EO, which again negates the need to  invoke MTP and again if there are phones that require EO in this type of call flow, then MTP will be inserted only for them
First of all (+5) to Manish on his excellent support so far. Great Job as always..
I do agree that you should use sip to sip all the way in your deployment, but some older relase of cucm do not work well with sip. If you want to keep your h323 setup, here is how to resolve your dtmf issue without using an MTP
##dial-peer to cucm
dial-peer voice xx voip
dtmf-relay h245-alphanumeric
//outbound to ITSP SIP dial-peer
dial-peer voice 101 voip
dtmf-relay rtp-nte digit-drop
Back your sip issues..
The logs show that your CUBE has negotiated the call based on G729 annexB. However CUCM MOH doesn't support G729annexB, If you check your IPVMS service parameters, you observe its only annex A that is supported. Hence the reason why the call fails once its put on hold. There is no codec renegotiation going on here.
So what are your options? You should remove G729 annexB from your codec list, so you only use G729annexa.
This brings us to the next issue. It looks like you have tried this and calls fail upon resuming them. Please send us logs as requested by Manish..
andeporter
For those of you who ran into this issue recently (as I did) I thought I would share the solution that worked for me. In the CUBE router configuration, I needed to configure midcall-signaling passthru media-change on the voice service voip profile in the router configuration, like this:
RouterName# config t
RouterName(config)# voice service voip
RouterName(conf-voi-serv)#sip
RouterName(conf-serv-sip)#midcall-signaling passthru media change
I hope this helps someone like it helped me!
andeporter
