06-30-2018 10:14 AM - edited 03-17-2019 01:08 PM
I'm probably overlooking something simple but I can't see the reason the gateway is not registering to the CallManager. I've double-checked the hostname (there is no domain name configured), end point configurations (the WIC-1DSU-T1-V2 is not being used so next step is to pull it from the router), verified that I can ping both CCMs (and the media resources are registering without a problem), etc. but I'm obviously missing something simple to get the MGCP gateway registered.
Any thoughts?
SPFLD-POOL-GW#show ccm MGCP Domain Name: SPFLD-POOL-GW Priority Status Host ============================================================ Primary Backup Ready 10.0.30.200 First Backup Registering with CM 10.0.40.200 Second Backup None Current active Call Manager: None Backhaul/Redundant link port: 2428 Failover Interval: 30 seconds Keepalive Interval: 15 seconds Last keepalive sent: 15:44:08 EST Jun 28 2018 (elapsed time: 1d19h) Last MGCP traffic time: 11:21:27 EST Jun 30 2018 (elapsed time: 00:00:15) Last failover time: 11:21:27 EST Jun 30 2018 from (10.0.30.200) Last switchback time: 11:20:57 EST Jun 30 2018 from (10.0.40.200) Switchback mode: Graceful MGCP Fallback mode: Enabled/OFF Last MGCP Fallback start time: None Last MGCP Fallback end time: None MGCP Download Tones: Disabled TFTP retry count to shut Ports: 2 FAX mode: disable Configuration Error History: ======================================================================================================================== 029588: Jun 30 16:23:25.171: //-1/xxxxxxxxxxxx/MGCP/mgcp_get_pkg_string(1523):[lvl=2]number of xgcp_pkg_types entry does not match. 029589: Jun 30 16:23:25.207: MGCP Packet sent to 10.0.30.200:2427---> RSIP 41077992 *@SPFLD-POOL-GW MGCP 0.1 RM: restart <--- 029590: Jun 30 16:23:25.215: MGCP Packet received from 10.0.30.200:2427---> 500 41077992 <--- 029591: Jun 30 16:23:25.607: %ENVMON-4-FAN_LOW_RPM: Fan 1 service recommended 029592: Jun 30 16:23:25.619: MGCP Packet sent to 10.0.30.200:2427---> RSIP 41077991 *@SPFLD-POOL-GW MGCP 0.1 RM: restart <--- 029593: Jun 30 16:23:25.623: MGCP Packet received from 10.0.30.200:2427---> 500 41077991 <--- ========================================================================================================================SPFLD-POOL-GW#show run | section mgcp SPFLD-POOL-GW#show run | section mgcp ccm-manager fallback-mgcp ccm-manager mgcp mgcp mgcp call-agent 10.0.30.200 2427 service-type mgcp version 0.1 mgcp dtmf-relay voip codec all mode out-of-band mgcp rtp unreachable timeout 1000 action notify mgcp modem passthrough voip mode nse mgcp package-capability rtp-package mgcp package-capability sst-package mgcp package-capability pre-package no mgcp package-capability res-package no mgcp package-capability fxr-package no mgcp timer receive-rtcp mgcp sdp simple mgcp fax t38 inhibit mgcp rtp payload-type g726r16 static mgcp bind control source-interface GigabitEthernet0/0 mgcp bind media source-interface GigabitEthernet0/0 mgcp profile default service mgcpapp service mgcpapp service mgcpapp service mgcpapp service mgcpapp service mgcpapp service mgcpapp service mgcpapp ======================================================================================================================== SPFLD-POOL-GW#show run | section ccm ccm-manager fallback-mgcp ccm-manager redundant-host 10.0.40.200 ccm-manager mgcp no ccm-manager fax protocol cisco ccm-manager music-on-hold ccm-manager config server 10.0.30.200 sccp ccm 10.0.30.200 identifier 1 version 7.0 sccp ccm 10.0.40.200 identifier 2 version 7.0 sccp ccm group 1 associate ccm 1 priority 1 associate ccm 2 priority 2 associate profile 1 register CFB_POOL associate profile 2 register XCD_POOL associate profile 3 register MTP_POOL ======================================================================================================================== SPFLD-POOL-GW#show inv NAME: "2851 chassis", DESCR: "2851 chassis" PID: CISCO2851 , VID: V01 , SN: FTX0927A4QP NAME: "WAN Interface Card - DSU/CSU T1 Fractional (V2) on Slot 0 SubSlot 0", DESCR: "WAN Interface Card - DSU/CSU T1 Fractional (V2)" PID: WIC-1DSU-T1-V2 , VID: 1.2, SN: FOC09243YJ7 NAME: "One port T1 voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "One port T1 voice interface daughtercard" PID: VWIC-1MFT-T1= , VID: 1.0, SN: 33717587 NAME: "Four port FXS DID voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "Four port FXS DID voice interface daughtercard" PID: VIC-4FXS/DID= , VID: 3.1, SN: FOC09192V9M NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 3", DESCR: "2nd generation four port FXO voice interface daughtercard" PID: VIC2-4FXO= , VID: V , SN: FOC09244805 NAME: "PVDMII DSP SIMM with three DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with three DSPs" PID: PVDM2-48 , VID: NA , SN: FOC09160CZH NAME: "PVDMII DSP SIMM with Two DSPs on Slot 0 SubSlot 5", DESCR: "PVDMII DSP SIMM with Two DSPs" PID: PVDM2-32 , VID: NA , SN: FOC09044QDP
Solved! Go to Solution.
06-30-2018 01:08 PM
You have not configured any of the endpoints, they all show unconfigured, it will never register without proper configuration in CUCM.
You also need to have a live circuit connected to the ports for the it/them to register.
06-30-2018 01:08 PM
06-30-2018 01:18 PM - edited 06-30-2018 01:20 PM
Try to configure ports on the CUCM side first. Looking at the screenshot they seem not to be configured yet.
Also, I cannot see the below command in your config which is required:
ccm-manager config
Thank you,
Mikolaj
**** PLEASE RATE IF USEFUL ****
06-30-2018 07:24 PM
Doh.
Thanks. For some reason, I had it in my head that I had to register the end point to configure it, not configure it to register it.
