Unable to register MGCP gateway with CCM (number of xgcp_pkg_types entry does not match)
apu
I'm probably overlooking something simple but I can't see the reason the gateway is not registering to the CallManager. I've double-checked the hostname (there is no domain name configured), end point configurations (the WIC-1DSU-T1-V2 is not being used so next step is to pull it from the router), verified that I can ping both CCMs (and the media resources are registering without a problem), etc. but I'm obviously missing something simple to get the MGCP gateway registered.
Any thoughts?
SPFLD-POOL-GW#show ccm
MGCP Domain Name: SPFLD-POOL-GW
Priority        Status                   Host
Primary         Backup Ready             10.0.30.200
First Backup    Registering with CM      10.0.40.200
Second Backup   None
Current active Call Manager:    None
Backhaul/Redundant link port:   2428
Failover Interval:              30 seconds
Keepalive Interval:             15 seconds
Last keepalive sent:            15:44:08 EST Jun 28 2018 (elapsed time: 1d19h)
Last MGCP traffic time:         11:21:27 EST Jun 30 2018 (elapsed time: 00:00:15)
Last failover time:             11:21:27 EST Jun 30 2018 from (10.0.30.200)
Last switchback time:           11:20:57 EST Jun 30 2018 from (10.0.40.200)
Switchback mode:                Graceful
MGCP Fallback mode:             Enabled/OFF
Last MGCP Fallback start time:  None
Last MGCP Fallback end time:    None
MGCP Download Tones:            Disabled
TFTP retry count to shut Ports: 2
FAX mode: disable
Configuration Error History:
029588: Jun 30 16:23:25.171: //-1/xxxxxxxxxxxx/MGCP/mgcp_get_pkg_string(1523):[lvl=2]number of xgcp_pkg_types entry does not match.
029589: Jun 30 16:23:25.207: MGCP Packet sent to 10.0.30.200:2427--->
RSIP 41077992 *@SPFLD-POOL-GW MGCP 0.1
RM: restart
029590: Jun 30 16:23:25.215: MGCP Packet received from 10.0.30.200:2427--->
500 41077992
029591: Jun 30 16:23:25.607: %ENVMON-4-FAN_LOW_RPM: Fan 1 service recommended
029592: Jun 30 16:23:25.619: MGCP Packet sent to 10.0.30.200:2427--->
RSIP 41077991 *@SPFLD-POOL-GW MGCP 0.1
RM: restart
029593: Jun 30 16:23:25.623: MGCP Packet received from 10.0.30.200:2427--->
500 41077991
========================================================================================================================SPFLD-POOL-GW#show run | section mgcp
ccm-manager fallback-mgcp
ccm-manager mgcp
mgcp
mgcp call-agent 10.0.30.200 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
 service mgcpapp
 service mgcpapp
 service mgcpapp
 service mgcpapp
 service mgcpapp
 service mgcpapp
 service mgcpapp
 service mgcpapp
SPFLD-POOL-GW#show run | section ccm
ccm-manager redundant-host 10.0.40.200
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.0.30.200
sccp ccm 10.0.30.200 identifier 1 version 7.0
sccp ccm 10.0.40.200 identifier 2 version 7.0
sccp ccm group 1
 associate ccm 1 priority 1
 associate ccm 2 priority 2
 associate profile 1 register CFB_POOL
 associate profile 2 register XCD_POOL
 associate profile 3 register MTP_POOL
SPFLD-POOL-GW#show inv
NAME: "2851 chassis", DESCR: "2851 chassis"
PID: CISCO2851         , VID: V01 , SN: FTX0927A4QP
NAME: "WAN Interface Card - DSU/CSU T1 Fractional (V2) on Slot 0 SubSlot 0", DESCR: "WAN Interface Card - DSU/CSU T1 Fractional (V2)"
PID: WIC-1DSU-T1-V2      , VID: 1.2, SN: FOC09243YJ7
NAME: "One port T1 voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "One port T1 voice interface daughtercard"
PID: VWIC-1MFT-T1=     , VID: 1.0, SN: 33717587
NAME: "Four port FXS DID voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "Four port FXS DID voice interface daughtercard"
PID: VIC-4FXS/DID=     , VID: 3.1, SN: FOC09192V9M
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 3", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO=        , VID: V  , SN: FOC09244805
NAME: "PVDMII DSP SIMM with three DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with three DSPs"
PID: PVDM2-48          , VID: NA  , SN: FOC09160CZH
NAME: "PVDMII DSP SIMM with Two DSPs on Slot 0 SubSlot 5", DESCR: "PVDMII DSP SIMM with Two DSPs"
PID: PVDM2-32          , VID: NA  , SN: FOC09044QDP
Jaime Valencia
You have not configured any of the endpoints, they all show unconfigured, it will never register without proper configuration in CUCM.
You also need to have a live circuit connected to the ports for the it/them to register.
java
if this helps, please rate
Jaime Valencia
java
Mikolaj Moryto
Try to configure ports on the CUCM side first. Looking at the screenshot they seem not to be configured yet.
Also, I cannot see the below command in your config which is required:
ccm-manager config
Thank you,
Mikolaj
**** PLEASE RATE IF USEFUL ****
Doh.
Thanks. For some reason, I had it in my head that I had to register the end point to configure it, not configure it to register it.
