07-15-2012 04:36 AM - edited 03-16-2019 12:12 PM
Hi ,
I am facing issue with my outgoing calls, i have configured mgcp on the remote location with my call manager 8.6.
I am unable to dial outgoing number but my incoming numbers are working fine. Please help me on this.Please find below the debug isdn q931 and debug voice ccapi in out output from the mgcp gateway.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.07.15 16:56:12 =~=~=~=~=~=~=~=~=~=~=~=
isdn q931
debug isdn q931 is ON.
COLRouter_01#debug voice cc
COLRouter_01#debug voice ccapi ino
COLRouter_01#debug voice ccapi inout
voip ccapi inout debugging is on
COLRouter_01#
Jul 15 11:26:34.501: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x49302BC4, Interface Type=6, Destination=, Mode=0x9,
Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=D000000002ef20a0000000F500000004)
Jul 15 11:26:34.501: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 15 11:26:34.501: :cc_get_feature_vsa malloc success
Jul 15 11:26:34.501: cc_get_feature_vsa count is 1
Jul 15 11:26:34.505: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 15 11:26:34.505: :FEATURE_VSA attributes are: feature_name:0,feature_time:1250622536,feature_id:61269
Jul 15 11:26:34.505: //61274/C4A19212B312/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Jul 15 11:26:34.505: //61274/C4A19212B312/CCAPI/ccCallSetContext:
Context=0x4913D7A8
Jul 15 11:26:34.505: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x48616C94, Interface Type=9, Destination=0.0.0.0, Mode=0x9,
Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=TRUE,
Jul 15 11:26:34.505: :cc_get_feature_vsa malloc success
Jul 15 11:26:34.505: cc_get_feature_vsa count is 2
Jul 15 11:26:34.505: :FEATURE_VSA attributes are: feature_name:0,feature_time:1250622312,feature_id:61270
Jul 15 11:26:34.505: //61275/C4A19212B312/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
Jul 15 11:26:34.505: //61275/C4A19212B312/CCAPI/ccCallSetContext:
Context=0x4913C308
Jul 15 11:26:34.509: //61275/C4A19212B312/CCAPI/cc_api_call_connected:
Interface=0x48616C94, Data Bitmask=0x0, Progress Indication=NULL(0),
Connection Handle=0
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Jul 15 11:26:34.509: //61274/C4A19212B312/CCAPI/cc_api_call_proceeding:
Interface=0x49302BC4, Progress Indication=NULL(0)
Jul 15 11:26:34.509: //61274/C4A19212B312/CCAPI/cc_api_call_connected:
Interface=0x49302BC4, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
Connection Handle=0
Jul 15 11:26:34.513: //61274/C4A19212B312/CCAPI/ccCallModify:
Nominator=0x1000, Params=0x49199020, Call Id=61274
Jul 15 11:26:34.513: //61274/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0xEF5A, digit_event=0x1, enable=TRUE, consume=FALSE)
Jul 15 11:26:34.513: //61274/C4A19212B312/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=61274
Jul 15 11:26:34.513: //61274/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x49302BC4, callID=0xEF5A, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Jul 15 11:26:34.513: //61274/C4A19212B312/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x49302BC4, Call Id=61274
Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
Jul 15 11:26:34.513: //61274/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x49199234, callID1=0xEF5A, callID2=0xEF5B, tag=0x0)
(confID=0x49199234, callID1=0xEF5A, gcid=0-0-0-0, tag=0x0)
Jul 15 11:26:34.513: //61275/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x49199234, callID2=0xEF5B, gcid=0-0-0-0, tag=0x0)
Jul 15 11:26:34.513: //61274/C4A19212B312/CCAPI/ccConferenceCreate:
Conference Id=0x49199234, Call Id1=61274, Call Id2=61275, Tag=0x0
Jul 15 11:26:34.513: //61274/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x7894, Source Interface=0x49302BC4, Source Call Id=61274,
Destination Call Id=61275, Disposition=0x0, Tag=0xFFFFFFFF
Jul 15 11:26:34.513: //61275/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x7894, Source Interface=0x48616C94, Source Call Id=61275,
Destination Call Id=61274, Disposition=0x0, Tag=0x0
Jul 15 11:26:34.513: //61274/C4A19212B312/CCAPI/cc_generic_bridge_done:
Call Entry(Conference Id=0x7894, Destination Call Id=61275)
Jul 15 11:26:34.513: //61275/C4A19212B312/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x7894, Destination Call Id=61274)
Jul 15 11:26:34.513: //61274/C4A19212B312/CCAPI/cc_api_caps_ind:
Destination Interface=0x48616C94, Destination Call Id=61275, Source Call Id=61274,
Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Modem=0x2, Codec Bytes=20, Signal Type=3)
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
Jul 15 11:26:34.513: //61275/C4A19212B312/CCAPI/cc_api_caps_ind:
Destination Interface=0x49302BC4, Destination Call Id=61274, Source Call Id=61275,
Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
Modem=0x2, Codec Bytes=160, Signal Type=2)
Jul 15 11:26:34.513: //61275/C4A19212B312/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=758)
Jul 15 11:26:34.513: //61274/C4A19212B312/CCAPI/cc_api_caps_ack:
Jul 15 11:26:34.517: //61274/C4A19212B312/CCAPI/cc_api_call_modify_done:
Result=0, Interface=0x49302BC4, Call Id=61274
Jul 15 11:26:34.517: //61274/C4A19212B312/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x7894, Call Id1=61274, Call Id2=61275
Jul 15 11:26:34.537: //61274/C4A19212B312/CCAPI/cc_api_voice_mode_event:
Call Id=61274
Call Entry(Context=0x4913D7A8)
Jul 15 11:26:34.541: //61274/C4A19212B312/CCAPI/ccSetDigitTimeouts:
Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms)
Call Entry(Inter Digit Timeout=4000(ms), Initial Digit Timeout=4000(ms))
Jul 15 11:26:34.541: //61274/C4A19212B312/CCAPI/ccRestartDigitTimeoutMsec:
Digit Timeout=0, Call Id=61274
Jul 15 11:26:34.541: //61274/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
Jul 15 11:26:34.541: //61274/C4A19212B312/CCAPI/ccCallReportDigits:
Jul 15 11:26:34.541: //61274/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Jul 15 11:26:34.541: //61274/C4A19212B312/CCAPI/cc_api_call_report_digits_done:
Call Entry(Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms))
Jul 15 11:26:34.625: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0004
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x0081, '117487021'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '0112977185'
Jul 15 11:26:34.645: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8004
Jul 15 11:26:34.717: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x8004
Cause i = 0x8081 - Unallocated/unassigned number
Jul 15 11:26:34.769: //61274/C4A19212B312/CCAPI/ccCallModifyExtended:
Nominator=0x49198F58, Params=0x491981A8, Call Id=61274
Jul 15 11:26:34.769: //61275/C4A19212B312/CCAPI/ccCallModify:
Nominator=0x18E30, Params=0x491983A8, Call Id=61275
Jul 15 11:26:34.769: //61274/C4A19212B312/CCAPI/cc_api_call_modify_done:
Jul 15 11:26:34.769: //61275/C4A19212B312/CCAPI/cc_api_call_modify_done:
Result=0, Interface=0x48616C94, Call Id=61275
Jul 15 11:26:34.853: //61274/C4A19212B312/CCAPI/ccCallModifyExtended:
Jul 15 11:26:34.853: //61275/C4A19212B312/CCAPI/ccCallModify:
Nominator=0x800, Params=0x491983A8, Call Id=61275
Jul 15 11:26:34.853: //61274/C4A19212B312/CCAPI/cc_api_call_modify_done:
Jul 15 11:26:34.857: //61275/C4A19212B312/CCAPI/cc_api_call_modify_done:
Jul 15 11:26:34.937: //61274/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0xEF5A, digit_event=0x0, enable=FALSE, consume=FALSE)
Jul 15 11:26:34.937: //61274/C4A19212B312/CCAPI/ccCallReportDigits:
Jul 15 11:26:34.937: //61274/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x49302BC4, callID=0xEF5A, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Jul 15 11:26:34.937: //61274/C4A19212B312/CCAPI/cc_api_call_report_digits_done:
Jul 15 11:26:34.937: //61275/C4A19212B312/CCAPI/ccGetCallStatistics:
Call Stats=0x4B2A2DBC, Call Id=61275
Jul 15 11:26:34.937: //61274/C4A19212B312/CCAPI/ccConferenceDestroy:
Conference Id=0x7894, Tag=0x0
Jul 15 11:26:34.937: //61274/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=61275, Disposition=0x0, Tag=0x0
Jul 15 11:26:34.937: //61275/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Jul 15 11:26:34.937: //61274/C4A19212B312/CCAPI/cc_generic_bridge_done:
Jul 15 11:26:34.941: //61274/C4A19212B312/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Jul 15 11:26:34.941: //61274/C4A19212B312/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
Jul 15 11:26:34.941: //61275/C4A19212B312/CCAPI/ccCallDisconnect:
Jul 15 11:26:34.949: //61275/C4A19212B312/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x48616C94, Tag=0x0, Call Id=61275,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
Jul 15 11:26:34.949: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 15 11:26:34.949: :cc_free_feature_vsa freeing 4A8AFB60
Jul 15 11:26:34.949: vsacount in free is 1
Jul 15 11:26:34.953: //61274/C4A19212B312/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x49302BC4, Tag=0x0, Call Id=61274,
Jul 15 11:26:34.953: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 15 11:26:34.953: :cc_free_feature_vsa freeing 4A8AFC40
Jul 15 11:26:34.953: vsacount in free is 0
Jul 15 11:26:35.033: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x0004
Jul 15 11:26:35.037: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8004u all
All possible debugging has been turned off
COLRouter_01#term no mon
COLRouter_01#
Pawan Arora
07-15-2012 06:23 AM
Judging by these ISDN messages it looks like all your routing is correct as the call is making it to and going out the local gw but the carrier does not like the dialed number you are sending them. Have you tried it without the national dialing access code and the city number (so drop the leading 0 11) since this is a local call.
07-15-2012 06:26 AM
Also have you been able to complete outbound calls to any other destinations out this trunk like LD or International.
07-15-2012 06:30 AM
i have tried to do the same with different route pattern and got the same
COLRouter_01#
Jul 15 13:28:00.681: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x4944AD74, Interface Type=6, Destination=, Mode=0x9,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=D000000002ef220b000000F500000007)
Jul 15 13:28:00.681: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 15 13:28:00.681: :cc_get_feature_vsa malloc success
Jul 15 13:28:00.681: cc_get_feature_vsa count is 1
Jul 15 13:28:00.681: :FEATURE_VSA attributes are: feature_name:0,feature_time:1227604808,feature_id:17
Jul 15 13:28:00.681: //17/BB87D50D800A/CCAPI/ccIFCallSetupRequestPrivate:
Jul 15 13:28:00.681: //17/BB87D50D800A/CCAPI/ccCallSetContext:
Context=0x49B629A0
Interface=0x486D4D54, Interface Type=9, Destination=0.0.0.0, Mode=0x9,
Jul 15 13:28:00.681: cc_get_feature_vsa count is 2
Jul 15 13:28:00.681: :FEATURE_VSA attributes are: feature_name:0,feature_time:1227604584,feature_id:18
Jul 15 13:28:00.685: //18/BB87D50D800A/CCAPI/ccIFCallSetupRequestPrivate:
Jul 15 13:28:00.685: //18/BB87D50D800A/CCAPI/ccCallSetContext:
Context=0x49B61500
Jul 15 13:28:00.685: //18/BB87D50D800A/CCAPI/cc_api_call_connected:
Interface=0x486D4D54, Data Bitmask=0x0, Progress Indication=NULL(0),
Connection Handle=0
Jul 15 13:28:00.685: //17/BB87D50D800A/CCAPI/cc_api_call_proceeding:
Interface=0x4944AD74, Progress Indication=NULL(0)
Jul 15 13:28:00.689: //17/BB87D50D800A/CCAPI/cc_api_call_connected:
Interface=0x4944AD74, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
Connection Handle=0
Jul 15 13:28:00.689: //17/BB87D50D800A/CCAPI/ccCallModify:
Nominator=0x1000, Params=0x4997C5F8, Call Id=17
Jul 15 13:28:00.689: //17/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0x11, digit_event=0x1, enable=TRUE, consume=FALSE)
Jul 15 13:28:00.689: //17/BB87D50D800A/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=17
Jul 15 13:28:00.689: //17/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x4944AD74, callID=0x11, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Jul 15 13:28:00.689: //17/BB87D50D800A/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x4944AD74, Call Id=17
Jul 15 13:28:00.689: //17/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x4997C80C, callID1=0x11, callID2=0x12, tag=0x0)
(confID=0x4997C80C, callID1=0x11, gcid=0-0-0-0, tag=0x0)
Jul 15 13:28:00.689: //18/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x4997C80C, callID2=0x12, gcid=0-0-0-0, tag=0x0)
Jul 15 13:28:00.689: //17/BB87D50D800A/CCAPI/ccConferenceCreate:
Conference Id=0x4997C80C, Call Id1=17, Call Id2=18, Tag=0x0
Jul 15 13:28:00.689: //17/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x9, Source Interface=0x4944AD74, Source Call Id=17,
Destination Call Id=18, Disposition=0x0, Tag=0xFFFFFFFF
Jul 15 13:28:00.689: //18/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x9, Source Interface=0x486D4D54, Source Call Id=18,
Destination Call Id=17, Disposition=0x0, Tag=0x0
Jul 15 13:28:00.689: //17/BB87D50D800A/CCAPI/cc_generic_bridge_done:
Call Entry(Conference Id=0x9, Destination Call Id=18)
Jul 15 13:28:00.689: //18/BB87D50D800A/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x9, Destination Call Id=17)
Jul 15 13:28:00.689: //17/BB87D50D800A/CCAPI/cc_api_caps_ind:
Destination Interface=0x486D4D54, Destination Call Id=18, Source Call Id=17,
Jul 15 13:28:00.693: //18/BB87D50D800A/CCAPI/cc_api_caps_ind:
Destination Interface=0x4944AD74, Destination Call Id=17, Source Call Id=18,
Jul 15 13:28:00.693: //18/BB87D50D800A/CCAPI/cc_api_caps_ack:
Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=9971)
Jul 15 13:28:00.693: //17/BB87D50D800A/CCAPI/cc_api_caps_ack:
Jul 15 13:28:00.693: //17/BB87D50D800A/CCAPI/cc_api_call_modify_done:
Result=0, Interface=0x4944AD74, Call Id=17
Jul 15 13:28:00.693: //17/BB87D50D800A/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x9, Call Id1=17, Call Id2=18
Jul 15 13:28:00.717: //17/BB87D50D800A/CCAPI/cc_api_voice_mode_event:
Call Id=17
Call Entry(Context=0x49B629A0)
Jul 15 13:28:00.717: //17/BB87D50D800A/CCAPI/ccSetDigitTimeouts:
Jul 15 13:28:00.717: //17/BB87D50D800A/CCAPI/ccRestartDigitTimeoutMsec:
Digit Timeout=0, Call Id=17
Jul 15 13:28:00.717: //17/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
Jul 15 13:28:00.721: //17/BB87D50D800A/CCAPI/ccCallReportDigits:
Jul 15 13:28:00.721: //17/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Jul 15 13:28:00.721: //17/BB87D50D800A/CCAPI/cc_api_call_report_digits_done:
Jul 15 13:28:00.801: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0007
Sending Complete
Standard = CCITT
Calling Party Number i = 0x0081, '1021'
Called Party Number i = 0x80, '2977185'
Jul 15 13:28:00.837: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8007
Jul 15 13:28:00.913: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x8007
Jul 15 13:28:00.957: //17/BB87D50D800A/CCAPI/ccCallModifyExtended:
Nominator=0x4997C530, Params=0x4997B780, Call Id=17
Jul 15 13:28:00.957: //18/BB87D50D800A/CCAPI/ccCallModify:
Nominator=0x18E30, Params=0x4997B980, Call Id=18
Jul 15 13:28:00.957: //17/BB87D50D800A/CCAPI/cc_api_call_modify_done:
Jul 15 13:28:00.957: //18/BB87D50D800A/CCAPI/cc_api_call_modify_done:
Result=0, Interface=0x486D4D54, Call Id=18
Jul 15 13:28:01.041: //17/BB87D50D800A/CCAPI/ccCallModifyExtended:
Jul 15 13:28:01.041: //18/BB87D50D800A/CCAPI/ccCallModify:
Nominator=0x800, Params=0x4997B980, Call Id=18
Jul 15 13:28:01.041: //17/BB87D50D800A/CCAPI/cc_api_call_modify_done:
Jul 15 13:28:01.041: //18/BB87D50D800A/CCAPI/cc_api_call_modify_done:
Jul 15 13:28:01.121: //17/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0x11, digit_event=0x0, enable=FALSE, consume=FALSE)
Jul 15 13:28:01.121: //17/BB87D50D800A/CCAPI/ccCallReportDigits:
Jul 15 13:28:01.121: //17/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x4944AD74, callID=0x11, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Jul 15 13:28:01.121: //17/BB87D50D800A/CCAPI/cc_api_call_report_digits_done:
Jul 15 13:28:01.125: //18/BB87D50D800A/CCAPI/ccGetCallStatistics:
Call Stats=0x49B727CC, Call Id=18
Jul 15 13:28:01.125: //17/BB87D50D800A/CCAPI/ccConferenceDestroy:
Conference Id=0x9, Tag=0x0
Jul 15 13:28:01.125: //17/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=18, Disposition=0x0, Tag=0x0
Jul 15 13:28:01.125: //18/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Jul 15 13:28:01.125: //17/BB87D50D800A/CCAPI/cc_generic_bridge_done:
Jul 15 13:28:01.125: //17/BB87D50D800A/CCAPI/ccCallDisconnect:
Jul 15 13:28:01.125: //17/BB87D50D800A/CCAPI/cc_api_get_transfer_info:
Jul 15 13:28:01.125: //18/BB87D50D800A/CCAPI/ccCallDisconnect:
Jul 15 13:28:01.141: //18/BB87D50D800A/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x486D4D54, Tag=0x0, Call Id=18,
Jul 15 13:28:01.141: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 15 13:28:01.141: :cc_free_feature_vsa freeing 492BC260
Jul 15 13:28:01.141: vsacount in free is 1
Jul 15 13:28:01.145: //17/BB87D50D800A/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x4944AD74, Tag=0x0, Call Id=17,
Jul 15 13:28:01.145: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 15 13:28:01.145: :cc_free_feature_vsa freeing 492BC340
Jul 15 13:28:01.145: vsacount in free is 0
Jul 15 13:28:01.225: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x0007
Jul 15 13:28:01.233: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8007u all
COLRouter_01#
07-15-2012 06:31 AM
NO. no calls are going out from this gateway
07-15-2012 06:51 AM
Pawan,
On your ISDN traces, ti shows that your telco provider is saying that you have called an incorrect number.,.
There is nothing wrong with your gateway or mgcp configuration because the calls are presented to your telco. They are disconnecting the call and the reason is that the number you have dialled does not exist.
You also need to ensure that the number you are dialling is correct..
is this number correct "2977185" or "0112977185" (Can your telco route it..they are saying they cant)
Get in touch with them and ask why they are disconnecting your call. This is not a gateway's problem.
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
07-15-2012 06:47 AM
I would also try setting the plan and type to ISDN subscriber it's possible but rather unlikely the carrier requires it. You might have to call them and find out why they are rejecting your setup message.
12-26-2013 07:41 PM
Hi Pawan Arora,
I got the same issue on our CUCM 8.6 and GW (C2951). If you have solution for this kind of issue, could you please help me.
Ayush
