Understanding Dial-peer Debug output
towertech
I would like to know how to understand what is happening in my debug below.
I notice that it matches my CUCM Session as one of the Dial peers. (Dial peers 7 and 8) But why does it attempt to match them multiple times?  Please see below...
DIALPEER:
debug voip dialpeer detail is ON (filter is OFF)
(Incoming)
023756: May 1 14:09:02.484 CST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ANSWER; Calling Number=996XXXXXXX
023757: May 1 14:09:02.484 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Is Incoming=TRUE, Number Expansion=FALSE
023758: May 1 14:09:02.484 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=, Expanded String=, Calling Number=996XXXXXXXT
Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
023759: May 1 14:09:02.484 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
023760: May 1 14:09:02.484 CST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ORIGINATE; Calling Number=996XXXXXXX
023761: May 1 14:09:02.484 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
023762: May 1 14:09:02.484 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
023763: May 1 14:09:02.484 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=4 Is Matched
(Outgoing?) Why is there multiplee matches...on the Dial Peers
023764: May 1 14:09:02.484 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=3005, Expanded String=3005, Calling Number=
Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
023765: May 1 14:09:02.484 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=7 Is Matched
023766: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=8 Is Matched
023767: May 1 14:09:02.488 CST: //-1/0DC611D28378/DPM/dpMatchCore:
023768: May 1 14:09:02.488 CST: //-1/0DC611D28378/DPM/MatchNextPeer:
023769: May 1 14:09:02.488 CST: //-1/0DC611D28378/DPM/MatchNextPeer:
023770: May 1 14:09:02.488 CST: //-1/0DC611D28378/DPM/dpMatchCore:
023771: May 1 14:09:02.488 CST: //-1/0DC611D28378/DPM/MatchNextPeer:
023772: May 1 14:09:02.488 CST: //-1/0DC611D28378/DPM/MatchNextPeer:
023773: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=3005, Expanded String=3005, Calling Number=3005T
023774: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
023775: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
023776: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ANSWER; Calling Number=3005
(Incoming)
023777: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
023778: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=, Expanded String=, Calling Number=3005T
023779: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
023780: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ORIGINATE; Calling Number=3005
023781: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
023782: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
023783: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=7 Is Matched
023784: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=8 Is Matched
023785: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
023786: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
023787: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
023788: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
023789: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
023790: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
023791: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
023792: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
023793: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
023794: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
023795: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
023796: May 1 14:09:02.488 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
023797: May 1 14:09:02.488 CST: //-1/0DC611D28378/DPM/dpMatchCore:
023798: May 1 14:09:02.492 CST: //-1/0DC611D28378/DPM/MatchNextPeer:
023799: May 1 14:09:02.492 CST: //-1/0DC611D28378/DPM/MatchNextPeer:
023800: May 1 14:09:02.680 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=996XXXXXXX, Expanded String=996XXXXXXX, Calling Number=
023801: May 1 14:09:02.680 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=4 Is Matched
023802: May 1 14:09:02.680 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
023803: May 1 14:09:02.680 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
023804: May 1 14:09:02.680 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
023805: May 1 14:09:07.472 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
023806: May 1 14:09:07.472 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
023807: May 1 14:09:07.472 CST: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
023808: May 1 14:09:07.472 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
023809: May 1 14:09:07.472 CST: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
TONY SMITH
Does the call work?  If so you can get a quick view of the dial peers it's using from "show call act voice | i PeerId", obviously run that command while the call is active.
Incoming calls are matched against dial-peers in the following order:
  1. "incoming called-number" dial-peers are matched against incoming called number
    • Match Rule=DP_MATCH_ORIGINATE
  2. "answer-address" dial-peers are matched against incoming caller-id
    • Match Rule=DP_MATCH_ANSWER
  3. "destination-pattern" dial-peers are matched against incoming caller-id (yes, counter-intuitive)
  4. per-IP or per-port special configuration
  5. dial-peer 0
So the multiple matches inbound are the router finding all of the matches and then figuring out which one to use. Same thing outbound. First, all matches are found. Then the router prioritizes which ones to use.
That's the basics. If you are having trouble, please provide your router's config (voice translations, interfaces, dial-peers, etc...but the whole thing is better). Also provide the original calling and called party information so we can analyze.
Maren
