Understanding MGCP Gateway Fallback Process
Fatty
I'm hoping some of you smart folks can help me understand what I'm seeing here.
This is what I have configured.
CM 11.5 >>>> SIP Trunk >>>> Cisco 4331 ( QSIG T1 From Avaya)
What I'm seeing is...
1. Layer 1 is UP
2. Layer 2 ( Q.921 Sig shows no RX from remote Avaya)
3. SIP trunk to 4331 is UP
4. D Channel on Avaya is down
I guess I'm lacking something basic here, since this is not an MGCP gateway, I don't have the option to bind l-3 and really not sure how this circuit is supposed to look from a "sh isdn st" command. I can provide all the necessary config etc, but did not want to post a novel here if I'm trying to do something fundamentally wrong.
I have done plenty of MGCP installations with T1 / E1 etc..very simple. I think what is confusing me is the QSIG over SIP.
R0g22
There is no dependability of call manager in this case, no l3 binds required.
ISDN status should show layer 1 as active and layer 2 as multiple frame established to be able
to receive calls on isdn layer 3.
Post an output for show isdn status here. Also enable “debug isdn q921” and shut/no shut the controller and add the output here. We should be able to see why is the d-channel down.
In addition to the above, have you made sure line coding, framing and switch type are correct on both avaya and ios gw ?
Hi, Thanks for taking the time to look at this. As requested, the attached
word doc contains the following output
1. sh inv
2. sh isdn st 0/1/1
3. sh controller t1
4. debug isdn q921
I assume all the routing for these channels is done in dial-peers...yes?
Again, thanks for taking the time here.
It looks as though the doc was stripped...here is the txt
sh inventory – 4331 ISR
AME: "Chassis", DESCR: "Cisco ISR4331 Chassis"
PID: ISR4331/K9        , VID: V04  , SN: FLM2209V1N6
NAME: "Power Supply Module 0", DESCR: "250W AC Power Supply for Cisco ISR 4330"
PID: PWR-4330-AC       , VID: V02  , SN: PST2147N2KT
NAME: "module 0", DESCR: "Cisco ISR4331 Built-In NIM controller"
PID: ISR4331/K9        , VID:      , SN:
NAME: "NIM subslot 0/1", DESCR: "NIM-2MFT-T1/E1 - T1/E1 Serial Module"
PID: NIM-2MFT-T1/E1    , VID: V05  , SN: FOC21502UPK
NAME: "subslot 0/1 db module 0", DESCR: "PVDM4-64 Voice DSP Module"
PID: PVDM4-64          , VID: V02  , SN: FOC22051AC3
NAME: "NIM subslot 0/0", DESCR: "Front Panel 3 ports Gigabitethernet Module"
PID: ISR4331-3x1GE     , VID: V01  , SN:
NAME: "module 1", DESCR: "Cisco ISR4331 Built-In SM controller"
NAME: "module R0", DESCR: "Cisco ISR4331 Route Processor"
PID: ISR4331/K9        , VID: V04  , SN: FDO22033JVW
NAME: "module F0", DESCR: "Cisco ISR4331 Forwarding Processor"
sh isdn st  - 0/1/1
Global ISDN Switchtype = primary-ni
ISDN Serial0/1/1:23 interface
        ******* Network side configuration *******
        dsl 1, interface ISDN Switchtype = primary-qsig
         **** Master side configuration ****
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = AWAITING_ESTABLISHMENT
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 1 CCBs = 0
    The Free Channel Mask:  0x807FFFFF
    Number of L2 Discards = 0, L2 Session ID = 221
    Total Allocated ISDN CCBs = 0
sh controller t1
T1 0/1/1 is up
  Applique type is Channelized T1
  Cablelength is long gain36 0db
  Description: - QSIG Circuit to Avaya G450
  No alarms detected.
  alarm-trigger is not set
  Soaking time: 3, Clearance time: 10
  AIS State:Clear  LOS State:Clear  LOF State:Clear
  Framing is SF, Line Code is B8ZS, Clock Source is Line.
  BER thresholds:  SF = 10e-3  SD = 10e-6
  Data in current interval (681 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 24 hours)
     0 Line Code Violations, 0 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
Q921 debug
Jun 14 15:08:38.728: ISDN Se0/1/1:23 Q921: Net TX -> SABMEp sapi=0 tei=0
Jun 14 15:08:39.729: ISDN Se0/1/1:23 Q921: Net TX -> SABMEp sapi=0 tei=0
Jun 14 15:08:40.729: ISDN Se0/1/1:23 Q921: Net TX -> SABMEp sapi=0 tei=0
Jun 14 15:08:41.729: ISDN Se0/1/1:23 Q921: Net TX -> SABMEp sapi=0 tei=0
Jun 14 15:08:47.730: ISDN Se0/1/1:23 Q921: Net TX -> SABMEp sapi=0 tei=0
Jun 14 15:08:48.731: ISDN Se0/1/1:23 Q921: Net TX -> SABMEp sapi=0 tei=0
Jun 14 15:08:49.730: ISDN Se0/1/1:23 Q921: Net TX -> SABMEp sapi=0 tei=0
Jun 14 15:08:50.731: ISDN Se0/1/1:23 Q921: Net TX -> SABMEp sapi=0 tei=0
Jun 14 15:08:56.733: ISDN Se0/1/1:23 Q921: Net TX -> SABMEp sapi=0 tei=0
Jun 14 15:08:57.733: ISDN Se0/1/1:23 Q921: Net TX -> SABMEp sapi=0 tei=0
Jun 14 15:08:58.733: ISDN Se0/1/1:23 Q921: Net TX -> SABMEp sapi=0 tei=0
Jun 14 15:08:59.734: ISDN Se0/1/1:23 Q921: Net TX -> SABMEp sapi=0 tei=0
Jun 14 15:09:05.736: ISDN Se0/1/1:23 Q921: Net TX -> SABMEp sapi=0 tei=0
Jun 14 15:09:06.735: ISDN Se0/1/1:23 Q921: Net TX -> SABMEp sapi=0 tei=0
Jun 14 15:09:07.736: ISDN Se0/1/1:23 Q921: Net TX -> SABMEp sapi=0 tei=0
Jun 14 15:09:08.735: ISDN Se0/1/1:23 Q921: Net TX -> SABMEp sapi=0 tei=0
R0g22
I don’t see a “Uaf” coming back from Avaya to bring up the d-channel.
On the controller the framing you have is SF rather than ESF, is that supposed to be like that ?
Check the cable. You should be using a PRI crossover utilising 1,2,4,5 pins only. And check in Avaya.
