Ungent Script double lable Unity express error
Hi all,
am using cme and cue ver 8.6. and having port and IVR licenses.
I  want to config an autoattent as follows. when caller calls in he hears  for english press 1 for other language press 2. Then when caller press 1  he hears options like for HR press 1 for help press 0 ... etc.
The main issue is when i create an add action for Sub menue, i receive erros when i save the config.
errors are:
duplicate lable, Dangling Go To, and Menue 2 not exist as shown in the attached.
plz help.
I have delete the default scrip aa.aef and the above is a new created script.......... how can i solve my issue
regards,
paolo bevilacqua
If the CUE editor says that there are errors in your script, very likely that is the case.
As alternative to editing, you can use my Universal AA script that does everything with only configuration. It can be acquired on the website mentioned in my profile.
thanks a lot Mr.Paolo for your replay,
I cant find it, can you please post me the url of the Universa AA script configuration as it is very urgent to me and i`ll be thankful to you.
regards,
As mentioned above, click on my profile.
