Unhiden directory CM 6.0
hector.aguirre
We need to unhide corporate directory for phones 7911-7941-7960 and 79 61. How can we do?
Graham Old
Level 7
Level 7
Login to CUCM.
Go to System/Enterprise Parameters
Scroll down to the Phone URL Parameters and check that you have a IP address for CUCM in the http string and not a name.
This can be caused by the phone not being able to map the name via DNS
Jaime Valencia
Let's start by finding out how you did that??
Did you change the directories URL from device config?
Configured another URL there?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
We need to see the coporate directory on the phone. At the moment  the phone only shows  call history in direcotries.
Thanks for help.
Graham Old
Level 7
Level 7
Login to CUCM.
You are a master, thankyou very much. This is the answer.
