Showing results forĀ
Search instead forĀ
Did you mean:Ā
Unified Communications Manager V10 upgrade downloads
amora1977
Hello there, I'm trying to find the CUCM V10 upgrade software, but on the downloads link  there is no download software for V10, can you help me with this thing? I think more people have the same question.
Thanks a lot
Aman Soi
you need to order through PUT [product upgrade tool] .Not available on CCO.
regds,
aman
Aman Soi
You can also refer the link and search for word PUT
https://supportforums.cisco.com/discussion/12103966/ask-expert-cisco-unified-communications-manager-cucm-version-100
regds,
aman
Jaime Valencia
.0 releases are never available for download from CCO, you need to order them via PUT.
java
if this helps, please rate
