Unified real time monitoring tool login
Process153
Could someone please clarify if the username and password this tool requires is the same as the username and password used to access the unity appliance from unix? What i mean is, if I was trying to log into the cli from the virtual host the appliance runs on.
2 Accepted Solutions
Aman Soi
you need to login in RTMT through  Application username and password .It is the same when u login  through GUI. in Unity Connection Administration.
what u are saying is OS Username and password which is through CLI [putty] or from vsphere client  used for DRS also?
regds,
aman
Wait for some time (may be 1 hour) and then try again.
Suresh
10 Replies 10
Aman Soi
regds,
aman
Hi Aman,
I've tried that and now the unity connection web interface is locked out even though I can still log into appliance cli.  This product is just an exercise in frustration.
you can try the command utils reset_application_ui_administrator _password from CLI to enter the new password.
regds,
aman
Thank you!  I've tried that and it reports "update failed trivial credential"  There is no other user account that I am aware of.  How could attempting to log onto the appliance with a cisco tool result in this utter mess????  My appliance even has its lockout policy disabled..... Utterly insane.  (I'm not aiming this at you aman of course.)  Greatly appreciate your help.
Suresh
May be the new password u are trying is similar to older one.
Thank you guys!  I lost it a bit there but i'm back into the web interface.  Patience has all but ran out for this app.....
I don't know Aman..... As far as I know the only password is the one I am using to access the web interface and the cli.  This one works for both but not for the RTMT.....
So now it works........ Can only assume I was typing the wrong password but its the same one i use everyday.....  I need some mint tea I think :)
Suresh Hudda
No, it's require application user credentials which is used into login through GUI.
Suresh
