05-08-2018 10:12 AM - edited 03-17-2019 12:46 PM
Can somebody help with my Unity service, I want to now how can i configurate and extencion :
When the commutator answer a call and say if you know the extension mark it now , I have all my services running and other extension with this services but i not the administrator, I only want to know how to do it.
Solved! Go to Solution.
05-08-2018 10:45 AM
05-08-2018 11:05 AM
Hi there
You can try configuring Directory Call handlers in CUC.
https://www.youtube.com/watch?v=THITwUrUfn8
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
05-08-2018 10:45 AM
05-09-2018 06:22 AM
Thank you Jaime for the video it help me a lot now i can understand more about my system.
Can i ask you something i have the next configuration:
When the commutator answers it have opcion 1.- admin 2.- ti and so on but it had another opcion we can dial an extension like 1234 and it forward to the extencion.
Now i have an extencion 5555 we i dial the commutator answer you can't be foward to this number. i had view a lot a videos but i haven't saw this configuration. how can i add this new extencion
Regards.
05-09-2018 09:39 AM
If 5555 doesn't exist in CUC
If you have a user with that DN, the adjust the transfer rules as you require.
And make sure your routing rules and CSS in CUCM allows the call.
05-10-2018 01:18 PM
Thank you but it did not work, yes the extension it is already configured all my system is working but i can not get that configuration.
I have add the new user to Unity i have copy every detail, but when i make a call to my company and the conmutator started:
if you know the extension dial it now, it does not forward to the extension i have add.
05-08-2018 11:05 AM
Hi there
Hope this helps!
Cheers
Rath!
