07-01-2019 05:42 AM
I want to setup an alternative greeting on a phone. Everything is working perfect..
I go to my voicemail on my phone, then Press 4 for Settings, then press 1 to change greetings
When I need to choose the language for the recording,(I want English(United Kingdom)) It gives me options to Press 1 for XXX, press 2 for YYY, press 3 for ZZZ, press 4 for English(United States)...... and finally Press 13 for English(United Kingdom) is there a way to change the order of the language, maybe switch English(United States) and English(United Kingdom) ?
/Chris
Solved! Go to Solution.
07-01-2019 07:25 AM
I do not think there is way to change the menu order but have you tried changing recorded language to English(United Kingdom) under Greetings (Standard/Alternate etc.) > Recordings > Recorded Languages in Unity Connection Administration.
07-01-2019 07:25 AM
