Unity 7.0.2 with failover-Add a new language AA
kbeelwar
I have unity 7.0 with failover. I want to add Russian auto attendant language to it.
I believe I need language license for it which I have ordered. Also I believe I need "install cd" which I am trying to figure out.
I have this cd.
installation disc with label
Will this be the one? Also, I need "exact" steps on how to go about this config. Can anyone pls help?
Thank you
Kads
Jaime Valencia
Adding the language instructions are here:
Adding Features to the Cisco Unity 5.x  System
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/upgrade/guide/ex/5xcuruge030.html
Instructions on how to create AAs on Unity have been covered plenty of times before (if you need assistance on that), you'll find plenty upon searching CSC.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hello
I am checking the link and the fist thing it says is
Task List for Adding Languages with Failover Configured
Begin the following tasks on the primary Cisco Unity server. The task  list alerts you when to update the secondary Cisco Unity server.
1. Obtain the license file(s) for the licensed additional languages
I am told I do not need license for additional language on unity 7.0 (this link is unity 5.x) Am I right?
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/7x/release/notes/702curelnotes.html
Checking this link, I think we need DVD number 6 which has Russian language.
Am I on the right path?
