IP Telephony and Phones
Labels
I have a router with a NM HD2 module for E1 and a VWIC2 giving me 4 x ports as well as a vwic3 card so total is 6x ports.The route came with lots of DSP`s  I`m moving some cards between different routers before sending it to a remote office. When I c...
iptuser55 by Level 6
  • 370 Views
  • 2 replies
Hi Folks - I have had this issue before and its back to haunt me again...I had a new gateway up and registered to the call manager yesterday and the PRI was registered and calls were working correctly. Then this morning we needed to swap out the cabl...
nellocon4 by Level 1
  • 464 Views
  • 4 replies
Call manger is able to send all external calls to voicemail - can the same be done on CME system? We have a requirement to only allow internal call to the classroom and prevent outside calls from transferring in.
jamurena by Level 1
  • 386 Views
  • 1 replies
Hi all,now I have a problem with the simple B-ACD AA script, I do the following configuration on the router, then is works(when I call the phone number from pstn, the AA script will answer the call with the prompt music, and then I can press "0" or 2...
oracat777 by Level 1
  • 386 Views
  • 0 replies
We plan to use Device Mobility for every device (around 25000 Phones) having them initially assigned on the big common device pool and having their Network subnet assigning the right Device Pool. The intended idea is to reduce the MAC. Solution will ...
robetrem by Level 1
  • 496 Views
  • 1 replies
