Unity 8.0.2 errors
Saima Harris
I received the following error from Unity .
Does anyone know what does below errors mean :
Event Type:       Error
Event Source:     CiscoUnity_AvCs
Event Category:
Event ID:         100
Date:             2012/10/31
Time:             11:38:01
User:             N/A
Computer:       UNITY1
Description:
Exception occurred and handled. File: E:\views\CU8.0.2.58\un_Miu\Miu\AvMiuTapiLineSvr\AvMiuLine.cpp at Line: 5470 - Error: 80004005H Call stack:
Exception Caught     : 0xc0000005
Exception Flags       : 0x00000000
Prev. Exception Record: 00000000
Exception Address     : 5E9B8223
NumberParameters = 2.
   Param[0] = 0x00000000
   Param[1] = 0x00000000
Thread ID: 10120
Processor Context:
ESI:02A75430 EDI:5EA4DD78
CS:EIP:001B:5E9B8223 SS:ESP:0023:143CED18 EBP:143CF084
DS:0023 ES:0023 FS:003B GS:0000 Flags:00010286
EIP: (Module:Offset) AvMiuTapiLineSvr.dll:0x48223 Process Name: AvCsMgr.exe
Event Type:       Error
Event Source:     CiscoUnity_Miu
Event Category:   Error
Event ID:         522
Date:             2012/10/31
Time:             11:38:01
User:             N/A
Computer:         UNITY1
Description:
Cisco Unity's telephony component has encountered a serious error.
EXPLANATION:
A serious failure has occurred on port 95 during telephony processing. Depending upon the severity of the failure, parties on this call could experience unexpected behavior or be disconnected. In some cases, further calls on this port will not be handled correctly.
TECHNICAL DETAILS:
Thread 0x00002690 had a failure on port 95 in method CAvMiuLine::Play()
DESCRIPTION: Exception caught!.
CALL SEQUENCE:
[11:37:56:092 - 0x00000610] Drop() - S_OK.
The strange thing in the above error is that PORT 95 is not enable to answer calls , so why would it send the error .
Saima
Chris Deren
Is that port perhaps listed int he voicemail line group in CUCM? If it is not enabled in Unity it should not be part of the line group.
Chris
Should I check in Hunt gp /Line gp in CUCM ?
