Unity AA Issue
Siva chinap
Level 5
Level 5
Dear All,
I configured Auto attendant for my help desk team, During IVR greetings the call should answered. But in my case after IVR the phone started ringing. I created a system call handler uploaded my personal greeting after the greeting sending to user voicemailbox. is there any way to configure during IVR the phone start ringing?
6 Replies 6
erikasasaki
So what you are trying to achieve is when a customer calls in instead of hearing ringback, they hear some sort of music on hold when thry are ringing a phone?
If it isnt, please provide exact flow of what behavior you would like to configure.
@ead,Thanks for your response.. exactly looking for the same call flow. I will explaing the call flow below
 In my scenario users from externally dial a main number. SYSTEM CALL HANDLER (During greeting it plays a welcome message) -->SYSTEM CALL HANDLER --> MY PERSONAL RECORDING(. When i press 1 it should play a message. during the message phone should ring.)
Currently my call flow after the greeting, the phone rings. But i am facing issue , after the greeting it takes 10 seconds to phone rings.
I don't quite understand why you are expecting your phone to ring while a "message" is playing. If your call handler is playing the message, then if you think about it your call is still in unity, and have not been transferred to CUCM.
In other way u call it as caller tune like in mobiles numbers.
Jaime Valencia
No, if you want to have a phone ringing while you're playing a greeting, that is not something you can do with CUC.
CUC will play a greeting, and THEN, it will ring the phone as per your config, or that you dialed during the greeting.
java
if this helps, please rate
@Jaime, Exactly i am looking for the same call flow,  In my scenarioi users from externally dial a main number. During greeting it plays a welcome message . When i press 1 it should play a message. during the message phone should ring.
As you mentioned after the greeting phone will ring, i did the same way. But i am facing issue , after the greeting it takes 10 seconds to phone rings.
