Unity Connection 1.2(1) upgrade to 1.2(1)SR2 - HOW??
gridnutter
All,
I need to upgrade my customers Unity Connection 1.2(1) servers to 1.2(1)SR2, however to get there I need to first upgrade to 1.2(1)SR1.
However the upgrade patch 1.2(1)SR1 is not available for download, so how do I get to 1.2(1)SR2?
Any help appreciated :-)
Craig
Jaime Valencia
Your best bet is to open a TAC and find out if they can publish it for you.
I thought you could install it directly but the RNs do state you need SR1 as a pre-requisite for SR2.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
Exactly right javalenc, I opened a TAC case and they published the SR1 update for me :-)
Many Thanks
Craig
