Showing results forĀ
Search instead forĀ
Did you mean:Ā
Unity connection 7 AA issues
Okechi Awujo
I configured AA on CUC 7 and anytime i tried to dial extension during the message i get the following prompt  "you cannot be transferred to this number the line is busy"... but the phone is not busy ... secondly after the message i want the call to be forwarded to an extension..
please help
You'll want to make sure that these DNs are in the CSS of the Voicemail Ports or SIP trunk. Also be sure that the Default Transfer restriction table allows this call.
Jaime Valencia
What's the transfer config for the DNs/subscribers you're dialing??
Are those already in something in CUC or have you enabled dialing non-subscriber DNs??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Some of the DNs are in CUC some are not .. the ones in CUC when you dail them get forwared striaght to voice mail.. then the ones not on CUC you get the prompt that it is busy...
i have enabled the dialing non-subscriber DN
