Unity connection 8.0 MWI issue
Saima Harris
Hi all,
One of my customer is having an MWI issue. When someone leaves a meesage it turns on but the next day it would turn off by itself even if they never checked the message .
I'm thinking something to do with every night MWI sync, is there an option that turns off all MWI while doing the daily synchronization, or may a BUG?
Thanks for your help
Saima
Jaime Valencia
Have you checked your message aging config??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
