Unity Connection 8.6 Cluster
ashley.pearce
Hi All,
Does the current design guidelines support multiple Unity Connection subscribers or is the recommended design still a publisher with a single subscriber? We are looking to deploy a 20k subscriber cluster and i was interested in load balancing the calls between two subscribers, leaving the publisher for message notification.
Ash.
Jaime Valencia
It's an active-active cluster, you may review the documentation here:
Cisco Unity Connection 8.x Clusters  (Active/Active High Availability)
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/connection/8x/design/guide/8xcucdg060.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
