Unity Connection 8.6 fwd routing rules
p-vincent
Hi all,
I have an unity connection system with multiple forwarded routing rules, I receive warnings for all of my forwarding rules stating that they have one or more conditions and that I should reconfigure them if necessary.. They all have the condition 'equal Dialed number'.
Routing rule 'Night_Message' is the last active
rule in the chain of direct routing rules. It is configured with at last one
condition, which means it might not handle all calls reaching it. The last
rule in the chain should be configured to handle all calls reaching it.
The standard forwarded routing rules "attempt forward" and "opening greeting" without any conditions are the last ones in the "chain" so they should take care of this?
Anyone has an idea what I should do to solve this?
thx in advance..
P
chandra_827
Hi All,
i have the same problem, but in 8.5. Do we need to do something to fix this warnings coming from the Daily Sytem configuration checks?
Please suggest...
