I'm setting up a Unity Connection subscriber account and for some reason I can't get release to switch working under their transfer options. If I select supervised transfer, the line on the CUCM side will ring. When release to switch is enabled, I get the subscriber greeting. While watching the port status monitor, I don't see Unity attempt the transfer on release to switch. Is there something basic I'm missing to get this to work? It's a SIP integration with CUCM 9.1, if that helps.
