Unity Connection config Phone Number Conversion
bo liu
Level 4
Level 4
i config UC,
in my AD the number is XXXX like 5945  5011
and i want they phone number in UC i want prifix a 1  like 15945 and 15011
how to config it in Phone Number Conversion ?
my confige .......
2 Accepted Solutions
Ok, Can you try this..
.*(\d{4})
Please delete the old pattern and add this one before testing
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Bo,
Here is the document..
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/administration/guide/8xcucsag306.html#wp1070054
9 Replies 9
Ayodeji Okanlawon
Bo liu,
If you want to prefix 1 to all the extension from Ldap then do this..
hi aokanlawon
thanks very much
and i want ask some question
(.*) means match any number
and 1$1 i known the first "1" is perfix  and the secound "1" is one number ....
but if i want add perfix like 22 how to do ....
i config 22@2 no use.....
no .....
aokanlawon i find...i config with you way...
but the phone no is 159451.... not 15945
.*(\d{4})
thanks .... this is useful....
can  you give me doc.
i want understand this.....
Bo,
thanks very much......
What are your options if you already performed the Directory Sync? Is there a way to put the genie back in bottle and start over so I can apply the phone number conversion?
e..
jamin ...i can't understand you say
