Unity Connection - Restricted or Unrestricted?
martin.chromy.1
  Does anyone know of a way to tell if an installed Unity Connection is running restricted or unrestricted version of software?
Current active version is 8.0.3.10000-8
5 Replies 5
ronpatel
Level 8
Level 8
If you don't see the word "unrestricted" after the version on CCMAdmin  or OS Admin page when you login you're running the restricted version  which is the "normal" version with all security features available to be  enabled.
regards
Ronak patel
Rate helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Cheers Ronak, thanks for your assistance
Where can I find a Cisco oficial information about how to verify if a version is restricted or unrestricted?
JD Chacon M.
Thank you for the reference, Jaime
JD Chacon M.
