Unity Connection SFTP Backup Number of Concurrent Connections
NPT_2
Level 2
Level 2
I am in hte process of setting up SFTP backup on our Unity Connection 8.x server, however my SFTP server only supports one simultanious sftp connection and it shows multiple connections coming from the Unity Disaster recovery backup application when I try to set it up, this causes my backup location setup to fail.  Is there a way to set the number of SFTP Streams that the Unity backup utility uses?  I don't seem to have this problem with Callmanager 7.x or CER 7.x, they work just fine.  Any thoughts?  Suggestions?
NPT_2
Level 2
Level 2
Never mind on that last question, I finally found a sftp server that works quite well (and free) for Callmanager/unity Etc.  I switched to the copSSH (uses OpenSSH SSL, Cygwin) and it works well and is quite easy to configured (compared to native Cygwin Open SSH and others).
