09-12-2012 06:44 AM - edited 03-16-2019 01:09 PM
On the following URL it says tha CUCXN 9.0 supports single inbox with IBM Lotus Domino, and that it requires 3rd- party solution via Esnatech and Donoma Software
but I didnt find any configuration guide for this feature. It's available for CUCXN 8.5 or 8.6? At least the Unified Messaging Service config on CUCXN 8.6(2) only permits MS Exchange servers (2003, 2007 and 2010)
On Esnateche says its solution is Cisco Compatible Certified for Cisco Unity Connection 8.5.1ES78 or 8.6.2ES20.
And on Donoma Software says they are compatible with Cisco Unity Connection server version 8.5, 8.6
Any information would be helpful.
TIA
Andres Pasten Calzada
ENTEL
11-09-2012 02:41 AM
I'm planning to use Donoma or Esnatech with CUC 9.0 and Lotus. Did you have un answer to know if one or both are compatible with CUC 9.0?
Moreover do you have a feature comparison between both solutions?
Thank you
Best regards
11-09-2012 05:03 AM
Sorry, I didn't receive an answer for my question. But on Cisco side says that CUC 9.0 supports the integration.
If you have more information, please let me know.
TIA
ENTEL
