Unity Connection Support for Exchange 2016?
MARTIN WEDDLE
Our organization is planning to upgrade to Exchange 2016. I was told EWS will not be supported in Exchange 2016. Given Unified Messaging uses EWS, I'm guessing Cisco has a plan to support exchange 2016 in future releases of Unity Connection. I'm wondering when support for Exchange 2016 will be added for Unity Connection? 11.5? 12?
5 Replies 5
Jaime Valencia
Roadmap questions cannot be addressed at CSC
If you're a partner, you can try the partner communities, otherwise, you would need to reach your SE for this kind of information.
java
if this helps, please rate
Makes sense. Thanks Jaime.
Found your post looking for that very answer.
Current docs show that 10.x and 11.x support 2016:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/unified_messaging/guide/10xcucumgx/10xcucumg010.html
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/11x/unified_messaging/guide/11xcucumgx/11xcucumg020.html#pgfId-1383295
On the link above for version 11 it needs to be upgraded to 11.0(1) Service Update 2 in order to support exchange 2016.  Does anybody have done the upgrade yet? We will be migrating to Exchange 2016 also in the next few months that's why I am interested to know what's going on with this.. any information would help Thank you
Hi 24 Franc,
I am wondering if you actually upgraded your Exchange 2016 with Unity 11.X, would be very helpful  if you can share your experience or throughts.
Thanks so much.
