IP Telephony and Phones
Labels
Hi,   Below is my configurations. I want to send calling number 5945151 and called number 0114430432 on SIP trunk. Phone from which i would dial 0114430432 has extension number 151 configured. Is my configuration is correct?   voice class codec 1 cod...
Hi,   I've recently setup a CUCM server, which has an H.323 trunk to an Avaya system, which is where all outbound calls exit from.  My Cisco IP phones work fine if the user places a call. However, they are not able to go into their call history and h...
I have recently upgraded our CUCM to ver 9.1.1 from 8.6.I use PRI and only receive the last 4 digits from the telco. When receiving inbound calls I send them to Unity Connections VM Pilot DN 2050.So a PRI call comes DN 2401 and then immediately trans...
jivorivor by Level 1
  • 1158 Views
  • 2 replies
If a user (attendee) calls in to the Conf Now access via a DID (10 digit) number and enters their attendee PIN, it works fine.  But if the Host calls in via a DID number,  as soon as they enter their PIN, the call drops. Calls initiated internally- i...
cabusch by Level 1
  • 419 Views
  • 1 replies
