Unity Connection Upgrade 8.0.3.20000-2 to 8.5.1.12900-7
Please, somebody,
What's the diference that's images?
UCSInstall_UCOS_8.5.1.12900-7.sgn.iso
UCSInstall_UCOS_UNRST_8.5.1.12900-7.sgn.iso
Thanks a lot,
Luciane de Medeiros
Rob Huffman
Hi Luciane,
99% percent of all builds are on the Restricted version. The Unrestricted version
was added to address the import/export requirements in certain areas of the world;
Cisco Unity Connection 8.5(1)—Restricted and Unrestricted Versions
This release provides two versions of the Connection software—restricted and unrestricted—that address import requirements for some countries related to encryption of user data and affects the following functionality:
Functionality
Restricted
Version of Connection
Unrestricted
SSL for IMAP connections used to access voice messages
Enabled
Disabled
Secure SCCP, SIPS, and SRTP for call signaling and media
Enabled
Disabled
File replication in a Connection cluster
Uses 128-bit encryption
Uses 40-bit encryption
Communications among networked Connection servers or clusters
Uses SMIME
Uses unencrypted
MIME
In the unrestricted version, if the disabled settings listed above are changed manually, Connection ignores the changes.
For the restricted version, "Restricted Installation" is included in the DVD label. For the unrestricted version, "Unrestricted Installation" is included in the DVD label and "UNRST" is included in the download filename.
The two-version change was introduced with Connection version 7.1(5a), but it was not included in the 8.0(x) releases. Versions 7.1(5) and earlier were equivalent to what is now referred to as the restricted version.
Caution With restricted and unrestricted versions of Connection software available, download software or order a DVD carefully choose the software carefully. Upgrading a restricted version to an unrestricted version is supported, but future upgrades are then limited to unrestricted versions. Upgrading an unrestricted version to a restricted version is not supported.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/release/notes/851cucrn.html#wp889793
You will likely be wanting the restricted version
Cheers!
Rob
Rob Huffman
Hi Luciane,
Functionality
Restricted
Unrestricted
Enabled
Disabled
Enabled
Disabled
Uses SMIME
Uses unencrypted
MIME
Cheers!
Rob
Rob,
Excellent, Thank you!
Cheers,
Luciane de Medeiros
