11-11-2011 08:44 AM - last edited on 03-25-2019 08:10 PM by ciscomoderator
Hello all, I am having a dickens of a time finding solution for this issue. I have the following (my concern is in the eth1 output below), I am thinking it is probably a switch configuration issue at this point, but as I do not have access to the customer's switches, I thought I would run it past the group here. I've not found anything in the forums on this yet, so thanks in advance for any help.
I am getting port alarms that show this information from our CUOM:
OperationallyDown: Interface card or network adapter operational state is not normal::Component= IF-CZTUSPINJ01VM03/4 [eth1]; AdminStatus= UP; DuplexMode= HALFDUPLEX; OperStatus= DOWN; MaxSpeed= 10000000; Type= ETHERNETCSMACD; Mode= NORMAL
Unity Connections -
admin:show version active
Active Master Version: 7.1.5.33900-10
Active Version Installed Software Options:
uc-locale-fr_FR-7.1.2.2-139.cop
admin:show hardware
HW Platform : 7845I3
Processors : 2
Type : Intel(R) Xeon(R) CPU E5540 @ 2.53GHz
CPU Speed : 2530
Memory : 8192 MBytes
Object ID : 1.3.6.1.4.1.9.1.587
OS Version : UCOS 4.0.0.0-39
admin:show network failover
Bond 0
DHCP : disabled Status : up
IP Address : 32.21.211.163 IP Mask : 255.255.255.240
Link Detected: no Mode : Auto disabled, N/A, N/A
Ethernet 0
IP Address : IP Mask :
Link Detected: yes Mode : Auto disabled, Full, 100MB/s
Ethernet 1
Link Detected: no Mode : Auto disabled, Unknown! (255), 100MB/s <<< Here is concern
DNS
Primary : Secondary :
Options : timeout:5 attempts:2
Domain : localdomain
Gateway : 32.21.211.162 on Ethernet bond0
11-11-2011 09:06 AM
Hi Chris,
I think this portion of the alarm probably tells the story;
It would seem that the switchport for eth1 has been hard coded
to half rather than full duplex as you nicely noted
Cheers!
Rob
11-11-2011 09:10 AM
Rob --
That's what I was thinking as well Rob, but just shortly got this info back from the switch guys --
USCZTSPILNJ02S#sh mac address-table | i e41f.13b7.0b5c
Vlan Mac Address Type Ports
30 e41f.13b7.0b5c DYNAMIC Fa1/0/4
USCZTSPILNJ02S#sh run int Fa1/0/4
Building configuration...
Current configuration : 321 bytes
interface FastEthernet1/0/4
description CONNECTION TO IPTel Server
switchport access vlan 30
switchport mode access
speed 100
duplex full
srr-queue bandwidth share 10 10 60 20
priority-queue out
mls qos trust cos
auto qos voip trust
no mdix auto
spanning-tree portfast
spanning-tree bpduguard enable
end
USCZTSPILNJ02S#sh int status | i Fa1/0/4
Fa1/0/4 CONNECTION TO IPTe connected 30 full 100 10/100BaseTX
I'm thinking it might be related to BUG
11-15-2011 06:44 AM
Just to point out that if you used the
command this will only the that MAC once in the address table
This will be of the live CUCM server port.
Even if both ports are up and all good you only see the MAC address on the primary port.
I think you will need to trace the cable for the port that is not working
Then look at the config on that port on the lan switch
alex
