unity connections study help?
Sarg .
Level 3
Level 3
Guys, please I need some advice. I am very interested in taking the unity support specialist exams 642-262 IUC.   However, the problem is that I have no idea about what material would be best for me to use as a study material or lab guides . Any suggestions will be appreciated.
thanks
Jaime Valencia
All the how-to can be found here:
Cisco Unity Connection
http://www.cisco.com/en/US/products/ps6509/tsd_products_support_series_home.html
Requirements:
System Requirements for Cisco Unity Connection Release 7.x
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/requirements/7xcucsysreqs.html
I believe that the deployment refers to the HA and active/active which are explained here:
Design Guide for Cisco Unity Connection Release 7.x
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/design/guide/7xcucdg.html
COBRAS is at the Unity Tools Depot online along with usage and help documentation.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
