Unity Express message retrival
wmostafa
Can i retrieve voice messages from outside my company, something the same way as we do with home answering machine .
We have CME 4.0 and NM-CUE
Markus Schneider
Sure. Either you can set up a number for the voicemail pilot number that can be dialed directly from the outside, or you make a custom auto attendant that has voicemail as an option, or you can simply call your own number (or any number on the system) and when it forwards the voicemail and you hear the greeting, press * and you can sign in using your ID and password.
