12-14-2008 08:45 PM - edited 03-15-2019 03:04 PM
I have CM6.1 with unity voice integration. the problem is that when a analog phone calling in from PSTN, unity play greeting, but the fist half of sentence get cut. With using cell phone calling in, I call hear full sentence. Don't know what cause problem. Any assitance will be very appreciated.
Thanks!
Steve
12-15-2008 02:14 AM
Hi Steve,
In Unity go to Tools Depot -> Switch Integration Tools -> Edit Switch Unity -> Incoming Calls tab. Here you can increase the value of "Delay before greeting" by few seconds.
12-15-2008 04:27 AM
Hi Marina,
Thank you very much for your help and I will try it.
Steve
12-15-2008 04:29 AM
Just keep in mind you *might* need to restart Unity to apply the change
12-17-2008 07:44 AM
Did this resolve your issue, what did you set the time to and did it require a restart?
12-18-2008 07:39 AM
When I change 2 rings and it works. Set time to 600 and it worked with two rings, same as change 2 rings. It did not requrie restart.
12-18-2008 08:19 AM
12-22-2008 08:11 AM
