Unity port busy error on Application event
garg.atul
We are running Unity4.0(5), in the application event I am getting the below mentioned error:
EVT_AVMIUMSG_PORT_STUCK
Source: CiscoUnity_Miu
Message: Port %1 has been busy since %2. The system threshold is %3 minutes, indicating that this port is currently unavailable and may be unable to handle further calls.
Any suggestion?
jbarcena
Level 9
Level 9
It could be that
an RTP stream is still active to that port. It is also possible that the port didn't
correctly disconnect after a call was completed. You can try to reset the port from the
CallManager, but in most instances a reboot of Unity is required to clear the port.
