01-05-2012 10:42 AM - last edited on 03-25-2019 08:11 PM by ciscomoderator
I have a lab router with a VIC2-FXO and VIC2-FXS cards. Everything has worked just fine on it until the other day I blew the config away to start over with the lab. Now I cannot configure voice ports.
A show diag shows the voice cards but on the PVDM slot it now shows the following:
JSM_1740_VG#show diag
Slot 0:
C1760 1FE VE 4SLOT DV Mainboard Port adapter, 5 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 3.0
PCB Serial Number : FOC07220T3X
Part Number : 73-7167-03
Board Revision : A0
Fab Version : 04
Product (FRU) Number : CISCO1760
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 16 41 03 00 C1 8B 46 4F 43 30 37 32
0x10: 32 30 54 33 58 82 49 1B FF 03 42 41 30 02 04 FF
0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Packet Voice DSP Module Slot 0:
Not populated
Packet Voice DSP Module Slot 1:
Unknown EEPROM cookie
VIC Slot 2:
Dual FXO Voice Interface Card
Hardware revision 1.1 Board revision K0
Serial number 0029485045 Part number 800-02495-01
FRU Part Number VIC-2FXO=
Test history 0x00 RMA number 00-00-00
Connector type WAN Module
EEPROM format version 1
0x20: 01 0D 01 01 01 C1 E7 F5 50 09 BF 01 00 00 00 00
0x30: A0 00 00 00 03 01 04 01 FF FF FF FF FF FF FF FF
VIC Slot 3:
Dual FXS Voice Interface Card
Hardware revision 1.1 Board revision B0
Serial number 0025082140 Part number 800-02493-02
FRU Part Number VIC-2FXS=
0x20: 01 0E 01 01 01 7E B9 1C 50 09 BD 02 00 00 00 00
0x30: 58 00 00 00 01 03 12 01 FF FF FF FF FF FF FF FF
Has anyone seen this before?
Solved! Go to Solution.
01-05-2012 12:17 PM
Try reseating the pvdm modules.
01-05-2012 12:17 PM
01-09-2012 07:23 AM
Looks like the slot went bad on the router. When I moved it to Slot 0 it came up, reseating in slot 1 gave the same error.
