Unknown WIC in slot(0/0), wic card has an unknown id of 0x51
aeriksson
Hi!
have a problem with a Cisco 2911/K9  with 1 x PVDM2-16 + the PVDM adapter and 2 x VIC2-BRI-NT/TE. This should be a supported combination.
We see the cards when doing a sh diag, but they do not appear at all when doing sh run, in fact no voice conf is shown at all. We can not for example see any voice ports and we can not issue the voice commands etc,
We have the proper UC license activated and it shows as active when doing sh lic
In the log we get Unknown WIC in slot 0/01, wic card has an unknown id of 0x51.
IOS is c2900-universalk9-mz,151-4.M5.bin
I can not find that this IOS should be incompatible.
Any ideas?
Gregory Garrian
Pascal Douce
I know it's an old post but I had the same issue and could not find the resolution on this post.
The fix for me was to enable uck9 license on my Cisco 2911 router.
Ensure it's permanent.
I used IOS version : c2900-universalk9-mz.SPA.155-3.M7.bin"
PBX-01#show license
Index 1 Feature: ipbasek9
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Medium
Index 2 Feature: securityk9
        Period left: Not Activated
        Period Used: 0  minute  0  second
        License Type: EvalRightToUse
        License State: Active, Not in Use, EULA not accepted
        License Priority: None
Index 3 Feature: uck9
        License Type: RightToUse
        License Priority: Low
Hope this will help you  or someone else.
Pascal
