how to register Polycom Soundstation IP 6000 with CME10.5 ??
Hello Guys
Need your help to register how to register Polycom Soundstation IP 6000 with Call manager Express 10.5 ???
i already have Voice Global Register !
i Can't find this mode in type mode ???????
Any Idea ???
Manish Gogna
Hi Hassan,
This phone is not a supported endpoint with CME 10.5
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme105spc.html
It it supports SIP then you can add it as a third party SIP endpoint. When adding a third party SIP endpoint you do not need to specify the 'type'.
Manish
- Do rate helpful posts -
8 Replies 8
Manish Gogna
Hi Hassan,
Manish
Dear Manish,
you are right i checked your URL !!!!
and i do no type and we will see .
Hi Manish, could you post your config?, I have the same issue
Ruben
Hey Jose ,
here is conf from voice register pool ##
voice register pool  99
 busy-trigger-per-button 2
 id mac 0004.F2F6.XXXX
 number 1 dn 99
 cor incoming inside default
 dtmf-relay sip-notify
 username 1106 password 1106
 codec g711alaw
 conference max-length 5
and don't forget to configure Phone with same thing as sip user !!
Hassan Fahmy
Hi Hassan,
Thanks for the post, kindly share procedure for adding IP 6000 as sip endpoint and also what do you mean by "don't forget to configure Phone with same thing as sip user "
HI GUYS,
i need help to add cisco polycom IP 7000 to my cisco unified communication Manager...
i will really appreciate your swift response.
please note that am currently running cucm version 10.5
Hi there
Please refer to the config guide.
http://support.polycom.com/global/documents/support/setup_maintenance/products/voice/dg_soundstation_ip_conference_phones_with_cucm.pdf
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
thanks alot,
i have complete configuration but for some reason i can call the polycom from my cisco IP phone but placing the call the other way round i.e calling my cisco phones with the polycom give me a tone 1"that the number does not exit"
