unlock cisco 7911
SHAIHAN JAFFREY
How to unlock cisco 7911 for manual network configuration changes?
5 Replies 5
Network Configuration -> **#
Thanks cradescu, but one thing more now the edit softkey is visible but when i click it . It says "That key is not active here"
Disable dhcp client on you ip phone, set dhcp - no.
I'm running into the same issue.  You press the sequence **# and get prompted for the password which you enter and still the get the "key is not active"  There's no way to disable the DHCP client if you cant get into network settings.  Any other ideas?
thank you..
You need to press 'No' button for DHCP. IP address will be activated then.
Post is quite old, but may help someone
