Unmapped Exception Manager line is selected for Cisco Unified Communications Manager Assistant control, go to manager configuration first.
mamaral
Hi!!
When configuring an assistant, i keep getting this error:
"Unmapped Exception Manager line is selected for Cisco Unified Communications  Manager Assistant control, go to manager configuration first."
Can anyone help me?
Best regards,
Miguel Amaral
Got the same problem and solved it. I place it here for anyone suffering the same.
My Manager phone was changed from one user to another, so the first user, although taken out from the phone, still had her manager profile configured with the device, and the assistant configurator gave the message
when it didn't knew which manager is the right one (it gives the message for zero or two managers).
Find the manager end user that should not be linked with the phone, then "Manager profile" and click Delete. The config of the Assistant should work now. Did for me!
Alfonso
