12-06-2014 07:31 AM - edited 03-17-2019 01:13 AM
Hi community,
the next great issue at this installation:
See the attached screenshot, i´m running into an unrecoverable error within the installation routing from CUPS 10.5 on a UCS-Server, BE6k.
It happened several times, i did:
Remove the machine completely from ESX
Deployed freshly the OVF for that persence server (cucm_im_p10.5_v8_v1.0.ova, also fresh downloaded from cisco)
Choosed "BE6K for 1000 Users" in that following dropdownmenu
Installed four times with the included ISO, whoch i mounted in that fresh machine
Tried two times already with the freshly downloaded and modified to bootable UCSInstall_CUP_10.5.1.12900-2.sgn, to save me time for updating it or avoid errors with the .ISO file on the datastore. BTW with checking media i couldn´t find any problems on the included one, also not the modified one. Both should work fine.
In any case i run in that error, several times, after quite a while having to wait for installation routine. Very frustrating...
Has perhaps anyone some ideas how to handle that problem? First time i encountered such an error, and i did some Presence-Installations before. No idea whats wrong.
Solved! Go to Solution.
06-09-2015 08:01 PM
Hi end2endtechs,
I had this problem before ... I had to recreate the bootable ISO, from the ISO that I downloaded from Cisco.
After it the installation works fine.
Hope this helps.
12-06-2014 11:01 AM
I face the same issue and I don't know what is happening.
is it the first time you install CUPS in this cluster ? or you are recovering the CUPS ?
the first time I install the server, I didn't face any issue. when I tried to install the same server for the 2nd time, it didn't complete.
I think it is a bug with this image.
One more thing, try to change the hostname of the CUPS in CUCM pub, and reinstall the server.
Anas
don't forget to rate the helpful posts
12-06-2014 02:19 PM
Hi Anas,
thanks for the input. I installed it first this time in that cluster, but i HAD prepared another install before, where i already removed the DNS reliability. So i thought OK, could be a reason and changed the name of the server there, like u recommended.
I´m running in the same problem again, now. Really annoying...
06-07-2015 06:26 PM
Did you ever find a solution to this?
06-09-2015 08:01 PM
Hi end2endtechs,
Hope this helps.
07-02-2015 02:52 AM
Sort of same for me, i got a new media from TAC...this then finally worked
